hey guys, hopefully you can help.
I have 2 4 ohm DVC 15" subs , & a mono (kicker) KX800.1 Amplifier @ 2 ohms.
How do i properly wire the (2) 4 ohm dual voice coil subs down to 2 ohms for the single channel amp @ 2 ohms?
Any assistance would be greatly appreciated.
You can't. 1 and 4 ohm are you only options with those subs.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
You cant,
You can wire to 1 ohm or 4 ohm
Some people have just used one voice coil on each sub...... i can tell you ive done it.... it lasted about 6 months till i smoked a coil.....
Please dont do this, just wire one DVC sub in parallel (++ --) for a two ohm load to run to ur amp.... better choice is to sell ur kicker amp and buy a 1 ohm stable amp in the wattage you need.
That's exactly what i thought. Thanks alot guys for the input. this amp is not 1 ohm stable, only 2 or 4 ohms. so they must have wired up for 4 ohms , which is half the power i need for those 2 subs from this amp. I knew something was not right. thanks for the help!
i would wire to 1ohm and run it, but thats me. I dont recommend it for you
This is exactly what I was thinking. After box rise the amp will more than likely see way above 2 ohm anyways so as long as he doesn't have some ultra efficient enclosure that amp will probably do it without issue.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
Not that, i just dont give a shit,.
