Daddy_ Posted September 4, 2016 Report Share Posted September 4, 2016 Just a question here. What would be better amp to drive 2 12" JL W6. The JL HD1200/1 or the Slash 1200/1v3. I know there fairly similar but tuning options are different and there right around the same price range. Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200 Link to comment Share on other sites More sharing options...
_paralyzed_ Posted September 4, 2016 Report Share Posted September 4, 2016 Whichever one makes you happy Daddy_. Link to comment Share on other sites More sharing options...
Daddy_ Posted September 4, 2016 Author Report Share Posted September 4, 2016 What also looking into the Alpine PDX M12 Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200 Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2016 Report Share Posted September 4, 2016 theres something clean about matching amps and subs Link to comment Share on other sites More sharing options...
Daddy_ Posted September 4, 2016 Author Report Share Posted September 4, 2016 Yeah do you know the difference between the HD and Slash amps? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200 Link to comment Share on other sites More sharing options...
diegoclass2010 Posted September 5, 2016 Report Share Posted September 5, 2016 Go with the slash for better tunning options, i had both, only cool feature about the hd is the small foot print Link to comment Share on other sites More sharing options...
Daddy_ Posted September 5, 2016 Author Report Share Posted September 5, 2016 Go with the slash for better tunning options, i had both, only cool feature about the hd is the small foot print What tuning option advantage does it have over the HD? Car: 2012 Acura TL Elite Head Unit: JL Audio Fix86 Front Stage : Alpine SPX-17PRO Rear Stage : Alpine SPR-60C Component Amp : JL Audio HD 600/4 Sub : 1 12" JL Audio W7 Sub Amp : JL Audio HD 1200 Link to comment Share on other sites More sharing options...
notorious97200 Posted September 5, 2016 Report Share Posted September 5, 2016 Go with the slash for better tunning options, i had both, only cool feature about the hd is the small foot print What tuning option advantage does it have over the HD? The Slash will make the same power between 1.5 and 4 Ohms IIRC. You shouldn't wire to 1 Ohm with those amps. I'd get the HD : I rather run smaller sized amps for the same power. Both are good amps. black BMW X1 2.0 l 192 hp OEM head unit, Amplifiers : Audison AP 8.9 amp with integrated DSP and Ampere Audio 1200. Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats. 2 SSA DEMONS 10" subs, in a 2.6 ft3 ported box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area. Link to comment Share on other sites More sharing options...
06RTCharger Posted September 12, 2016 Report Share Posted September 12, 2016 Go with the slash for better tunning options, i had both, only cool feature about the hd is the small foot printWhat tuning option advantage does it have over the HD? The Slash will make the same power between 1.5 and 4 Ohms IIRC. You shouldn't wire to 1 Ohm with those amps.I'd get the HD : I rather run smaller sized amps for the same power. Both are good amps. Looks like Both those models have the R.I.P.S. So they both offer same output throughout those ohms. The slash has more EQ abilities with the parametric bass EQ. But then again its just for subs, i'd think if u have a HU with eq abilities u could use that or a dsp and not need the eq on the amp. The hd is $100 cheaper and has the same output. Also the the HD is wide-range, with a filter freq range of 50-500hz and freq response of 6hz- 8k hz. Slash is a more strict sub application with a filter range of 40-200hz and freq response 5hz-250hz, big difference there. Another thing u could consider is size, HD is 10x8, slash 19x9. Thats all i could notice, im the noobiest of noobs tho lol i still wanna offer help tho. Good luck Link to comment Share on other sites More sharing options...
dolarbilz Posted September 12, 2016 Report Share Posted September 12, 2016 Slash is my vote had two and miss them . I prefer bigger amps seems to me there's more in them ,than the small footprint amps. Link to comment Share on other sites More sharing options...
