Impedance rise, not your typical question
Let us know what you find out.
What frequency is your box tuned to?
Builds:
I'm in for knowledge here.
My gut tells me that the more efficiant way to run subs is to run the runs from the amp in parallel to coil in series coils
I would assume whatever way you wire, the one with the higher resistance for an individual sub would have a lower rise just because you are looking at a cooler coil inherently
changed: for me trying to juggle work and this... couldn't put together a complete thougtht
Although impedance does rise due to power compression, I believe the biggest factors to be the tuning of the box port and cabin resonant frequency. It seems that one way to reduce the amount of rise is to wire down to a low resistance?
Pioneer 80PRS
So testing has been done, Series coils Parallel subs @ 51Hz was 2.8ohm I mistyped when I started this topic (went over my notes again). I then rewired yesterday and retested Parallel coils and Series subs @51Hz was 3.6ohm. So there is a real measurable difference in my case. And it looks like I will be changing my subs back for INAC but I am not giving up on these beasts I will find the trick to making them work for me.
Retired from SPL again....
2016 IASCA Truck/Trunk 2 Champion 151.8db
2016 IASCA Truck/Trunk 2 World Record Holder
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
Now I'm going to re wire my subs. Lol
Pioneer 80PRS
If the amp is putting out the same power to the same amount of subs the coils will be the same temperature no matter how you wire it. They'll be dissipating the same power either way.
My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build
This forum has a massive boner for ridiculous electrical upgrades.
did you see the video above?
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
Comparing a 0.5ohm coil and a 2 ohm coil? Heat is calculated from I2R so provided the arrangement of coils is pulling the same current and has the same resistance, it should dissipate the same amount of heat.
Edit: I'm looking at it as a whole system. That power has to go somewhere. Each coil may dissipate less heat if wired in parallel but it is right next to another coil dissipating just as much.
Think about it as 2 dual 1ohm subs. You have a final 1ohm load whether you do series-parallel or parallel-series. And in both situations, with 2500w like in the video, you have 50A being split across 2 paths, and flowing through 2 coils on each path. All you are changing is whether the link in between is. The only difference is that with the series-parallel you don't have the link between the middle.
You could add this to the series-parallel by wiring between series coils on the subs together. Or you could take it out by leaving out 2 connections from the parallel-series layout.
  • Who's Online   0 Members, 0 Anonymous, 843 Guests (See full list)
