Lithium- Why isnt everyone convinced
My batteries rest at about 13.4-13.6
Rarely do I charge them outside of just driving. Always stock alt. I have a 320 amp alt in the closet that I never even installed
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
What cells are you running? I agree fully that 40Ah isn't enough
I use Winston 90 ah cells
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
awesomesauce. that's what I was looking into.
40ah isnt enough ? :( I have 1 b2 40ah for a 3krms amp on the 140a stock alt. Hoping for above mid 12's.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
40ah is still 40ah. Sure it'll be fine due to the power density of lithium. It's more of a personal thing saying 40 isn't enough. The way I look at it (even though we never do) if you run your system off, drawing 40A, it'll be dead in an hour. I'll eventually be running 180ah of lithium.
The reason I say 40ah isn't enough is due to the many many people who think the one battery can handle 10k+
That's the main reason I despise xs power's naming scheme. It's misleading
Learn how the shit works and determine what you need. Don't let companies tell you what you need
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Yeah I can understand that. Id never run 10k on that little of an AH. Personally I think 3k is pushing it with a 100a alternator. but im sure it has its uses. No HO alt and 1/3 the weight to run my same amplifier.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
  • Who's Online   1 Member, 0 Anonymous, 1738 Guests (See full list)
