Question about a circuit
Okay, so i'm wanting to go from a 5vdc power supply to a 1.45-1.65vdc IR LED. How could I step the voltage down to match the specs of the LED? I've looked everywhere for this and haven't really found an answer to my question. I know it's probably really simple but I have no idea on how to do it. I thought of maybe just using a resistor but this has been said to be a bad idea buy a lot of people I was reading. If you're wondering i'm trying to tap into the 5v power wire from a USB connected to a webcam to also power a Infrared LED that is rated to 1.45 - 1.65 v/ 20 mA.
I have no idea why a resistor wouldn't work.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
Something about constant current draw and what not. I mean, if it will work then that makes my life easier.
If I were to just use a resistor would I just put a 175 ohm resistor (assuming the LED is operating at 1.5v and 20 mA thus providing a resistance of 75 ohm) would that get me to my 1.5 V goal?
The voltage drop across an led is .5 volts. Might as well be a dead short with no resistor.
Pioneer 80PRS
Look on amazon for a step down D.C. Module they have tons of them 5v to 1.5v
2022 Ford Maverick on 22’s        Skar SK1500.1 on 4 Skar VD-8’s        Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4                                                 LC2 for audio control  , XS Power D680 XS Series Extra Battery
why not use a potentiometer?
This ...
This ...
I tried finding some that would work for me but couldn't. Probably just looking in the wrong places. Every time I found something that may work it was rated at 12v not 5v. I also need something that can be screwed in or soldered to a blank circuit board that can be screwed in. I don't want a whole bunch of loose wires and components seeing as this is for a class project and I need it to look fairly decent and thought out. My original idea was to use a pot of some sort but, like I said, I couldn't find one that was suitable.
I don't understand what you're trying to say.
