2015 Chevy Sonic/Wall/4 PSI 15's/SA 6K/Active/Arc/CDT/Singer/US Alt/XS
Yeah he did! Can't wait to see the finished product.
2000 Toyota Solara SEV6, 200 amp alternator, Jensen VX7020, Hifonics American Warrior Taurus X, Hifonics American Warrior Centurion X, JBL Club 6500C, Power Acoustik XP2K-4102, Coustic Power Logic HT-612 in a BP4.
Cut my second door baffle today
Glued two of my kerf boards together
After screwing around with clamps for a bit, decided to just trace the face board and make a jig for the kerfed box walls
Lots of PL later...
My little helper.  SO fucking delicious.
It'll be fully dried up tomorrow
Snug in the jig
IG @walledsonic
I cut the cabin vents out a few weeks ago and blocked them up. I quickly realized that you cant block these completely.  Air needs to move through these when your windows are down on the freeway:
Friday I picked up the custom "Moisture Accumulator/Separator" I ordered for my cabin vents.  They allow air to pass unrestricted (mostly) and they have a 98% moisture capture rate.  I need to connect a drip line for a drain.  More on these soon
IG @walledsonic
Kerf looks amazing dude, keep up the great work.  Sucks about roof but yea thats what happens when you foam a lot at once.  =(  Its solid tho so.....
gratz on name change
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Finally found a use for my lead acid battery.
Inside view, face board is glued on.  All wood and glue at this point.
Gotta love that flush trim bit
Followed up with a 3/8 roundover
Ended up using the 1/2" roundover, a bit shallow until i do the final touches
The Silver Flutes will fit.  One fits over where the 6.5" is located and the other will fit about where Im holding it below
Need to jigsaw each pod little by little so the back face contours to the door.
One more look before I get the pod fitted up.
IG @walledsonic
Freehand jigsaw action
The final cuts are close fitting
Mock up
Now I can install the door panel, reach thru the speaker holes, then trace the shape of the box onto the door.  Then more custom cuts and rivnuts, then lots of deadening.  Its coming along though.
IG @walledsonic
Pods look killer! Are you going to leave the back of the pod open to the door or is there going to be a back panel? Tuned in for more.
Pioneer 80PRS
  • Who's Online   1 Member, 0 Anonymous, 1062 Guests (See full list)
