ShadeTreeMechanic Posted December 12, 2016 Report Posted December 12, 2016 Wow you are going to run what sub on what amp? I got to see this. You are going to need most of the room behind the seats for this box. Having a long port that is big enough to tune that low is going to take some room. Normally the box should be smaller when over powered to help it live but will make it hard to keep the port inside the box. Maybe someone with modeling software will chime in with a better explanation. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Ron36 Posted December 12, 2016 Report Posted December 12, 2016 Wanted to read all this but my brain will not allow me holy long post 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Skullz Posted December 13, 2016 Report Posted December 13, 2016 Your over thinking and wanting to over do it. 5k is a ton of power and you better have your electrical squared away before you start dropping coin on subs and amp. You better brace the hell out of that thing back there and deaden the shit out of it, and 5k on one sub is asking a lot even though you think you'll do just a few minutes at a time, we all know how that goes over time. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Broke_Audio_Addict Posted December 13, 2016 Report Posted December 13, 2016 Zv5 or nsV3 for sq? And on 5k? Good luck. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals.
DLHgn Posted December 13, 2016 Report Posted December 13, 2016 .....What happened to his post/comments?
trilumus Posted December 13, 2016 Author Report Posted December 13, 2016 .....What happened to his post/comments? I was looking for intelligent discussion but the only one person got close "ShadeTreeMechanic". The rest just proved that I'm better off using my own brain, it hasn't let me down yet. Good Luck and Good Times gents. S
ShadeTreeMechanic Posted December 13, 2016 Report Posted December 13, 2016 Don't let it get to you. Nobody means to offend you. It just sounds like a lot of power for one sub so its going to get some attention. If you are willing to bounce some ideas off of us we can help you get to where you want to be. I have been all the way out in left field a few times and they always manage to pull me back. lol Everyone has their own ideas about what they want and we welcome anything you have to share. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
