Hissing noise from speakers
Try bench testing everything if your able to do that to see if you can isolate the problem to a specific piece and rule out the car or wiring, and if not you'll know you have an issue inside somewhere you need to track down.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
I use an EQ with a built in pre amp to drive the line. This allows me to keep the gains really low on my amps.
Pioneer 80PRS
you could try grounding the amps to a closer chassis/frame grounding point, but I'm not so sure that would eliminate the noise. It's possible, but a direct ground to battery should be fine the way you have it. Did you double check to see if the noise is still there with the RCAs not connected to the amp, like you said you would?
Did you try with another amp ? Or without the external eq ? It may be the equipments, not the install.
black BMW X1 2.0 l 192 hp
OEM head unit, Amplifiers :  Audison AP 8.9 with integrated DSP and Ampere Audio 1200.
Focal ES 100 K in front doors, and Dayton RS 180 for midbass under the front seats.
2 SSA DEMONS 10" subs, in a sealed box. SecondSkin Damplifier on front doors, and Luxury Liner Pro for the cargo area.
Also tried running a new remote wire from fuse panel still have noise, car is a 2011 vw mk6 gti if that helps at all.
Doing all this without the 3.sixty installed.
I'm using anderson plugs so I can remove the install quick if need be to carry large items, thus wouldnt be a problem would it? They are soild conections.
Turn your gain down.
Pioneer 80PRS
Still does it while turned all the way down.
When I flick the amp to LPF I get a really high pitch noise, on Full and HPF it drops to a hissing noise changing the eq doesn't change a thing. Gain changes the hissing volume but still able to hear it while gain is all the way down.
Does it do it with the car engine off or only when running?
Pioneer 80PRS
