How much can a Rockford T0 10d2 really handle??
Michael Dean
Rockford says 550rms, these subs are a beast does any one know or have put them to the test?
i currently have two on a t1500bdcp?? Thanks
its got the same parts as the t1 minus the copper cooling plate on top of the magnets. id give them up to 800 clean power but keep a good nose out for them smelling. heating is more so the issue with them imo.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Thanks for the info, just trying to see what I can give them with out full distruction.
My fiance's son had a T0 12" last for about a year with a bridged HiFonics Series VII Zeus on it before it failed.  That's about 9 months longer than I thought it would last.
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
What ohm were you running? The hifonics is not known for clean sound that's for sure. How did you set the gains for the sub?
4 Ohms mono.  The Zeus is rated for 900 watts RMS into 4 Ohms mono, but typically makes a scant more.  Set the gain with a DD-1 of course . . .
Wow that is odd. But that is over rated power of the sub so if I keep it close to rms and not pound the hell out of them I should be good.
You have to ask yourself how long do you want to run the sub. I have contacted RF before to ask about there subs and speakers. Basically They underrate there amps but are spot on on rms and peak wattage of there speakers. And since music is recorded differently, distortion levels may vary. Over powering your subs can be dangerous, shortening there life. I own a T1D412 running it off a 1999 RF Power 10001a at 1 ohm so it getting close to 1K and does well but i dont full tilt and on this system its in.
Long story short run it how you want, but if you value it stay close to rms and enjoy. Not enough output for you add more subs, move up the T-line series subs.
I would say about 550 W.
Krakin's Home Dipole Project
http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370
Krakin, are you some sort of mad scientist?
I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
What you hear is not the air pressure variation in itself
but what has drawn your attention
in the two streams of superimposed air pressure variations at your eardrums
An acoustic event has dimensions of Time, Tone, Loudness and Space
Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears,
thus no formula can achieve a definite effect for every listener.
  • Who's Online   0 Members, 0 Anonymous, 6409 Guests (See full list)
