Sequoia_Bass Posted January 28, 2017 Report Posted January 28, 2017 I currently use my iphone as my "music source" in my car. I run a 3.5mm to RCA Adapter. Sending a single pair of RCA's to my Rockford R150x2. Then i run RCAs from the Rockfords RCA outputs to my sub amps using Piggyback RCAs. My question is, Would there be any benifit buying a headunit and using that as my "Music source"? More clear sound? I would still plug my phone into headunit and play from my phone. Any input would be greatly appreciated!
Wasteland_Audio Posted January 28, 2017 Report Posted January 28, 2017 Please for the love of all things holy, get a head unit. A headphone jack puts out almost no voltage when hooked directly to rca. Getting a head unit will give the amps a proper amount of signal voltage and give you the required adjustment for everything. Plus you will have a dedicated subwoofer output that will clean the signal up tremendously. Also you will get an even better signal if you get an iPod ready deck and hook it up with a usb instead of 3.5mm.
06RTCharger Posted January 28, 2017 Report Posted January 28, 2017 maybe if you used a headunit with usb input, and use the usb port on ur phone to tranfer the music. I think bluetooth could possibly be a better signal than 3.5jack. Theres so many variables tho, it would be best to try it out for urself, hopefully u can try something out before u purchase it.
Krakin Posted January 28, 2017 Report Posted January 28, 2017 1 hour ago, Wasteland_Audio said: Please for the love of all things holy, get a head unit. A headphone jack puts out almost no voltage when hooked directly to rca. Getting a head unit will give the amps a proper amount of signal voltage and give you the required adjustment for everything. Plus you will have a dedicated subwoofer output that will clean the signal up tremendously. Also you will get an even better signal if you get an iPod ready deck and hook it up with a usb instead of 3.5mm. Why would a low voltage signal matter before amplification? Krakin's Home Dipole Project http://www.stevemeadedesigns.com/board/topic/186153-krakins-dipole-project-new-reciever-in-rockford-science/#entry2772370 Krakin, are you some sort of mad scientist? I would have replied earlier, but I was measuring the output of my amp with a yardstick . . . What you hear is not the air pressure variation in itself but what has drawn your attention in the two streams of superimposed air pressure variations at your eardrums An acoustic event has dimensions of Time, Tone, Loudness and Space Everyone learns to render the 3-dimensional localization of sound based on the individual shape of their ears, thus no formula can achieve a definite effect for every listener.
Wasteland_Audio Posted January 28, 2017 Report Posted January 28, 2017 9 hours ago, Krakin said: Why would a low voltage signal matter before amplification? I've always found that a higher voltage (between 2 and 4 volts) produced a cleaner signal than say a .2 volt signal with the gain cranked on the amp to match it. That's just my experience tho, it may just be that you can set your eq much more accurately on a deck than you can an ipod.
Soccerballzs Posted January 28, 2017 Report Posted January 28, 2017 Headunit will give you more tuning options then just a iphone. Not a fan of Android or IPhone for source unit. Lacks the ability to tweek audio. http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
Sequoia_Bass Posted January 29, 2017 Author Report Posted January 29, 2017 Thank you guys so much!! Will be getting headunit soon!!
Sequoia_Bass Posted February 16, 2017 Author Report Posted February 16, 2017 I ordered an pioneer MVH-X690BS 2 Din Radio. Quite excited to finally have head unit! I will post picture when it arrives and i install it
meade916 Posted February 16, 2017 Report Posted February 16, 2017 On 1/28/2017 at 11:02 AM, Wasteland_Audio said: I've always found that a higher voltage (between 2 and 4 volts) produced a cleaner signal than say a .2 volt signal with the gain cranked on the amp to match it. That's just my experience tho THIS ^^^ More (clean) source voltage, less amp gain. Less floor noise = better. All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
Sequoia_Bass Posted February 16, 2017 Author Report Posted February 16, 2017 Sounds like it's gonna be alot better quality! Very happy i purchased it
