dsw422 Posted February 5, 2017 Report Posted February 5, 2017 Hey guys, My buddys subs start to stink when played full tilt for a short while. He's trying to find out y. He has verified they have a clean signal (amp set with dd-1). Ohm load at amp is 1 ohm ( 4 sa 15s on a CT sounds 3k). Wall is 18 cuft tuned to either 32 or 26 Hz via adjustable port.. Any help is appreciated! 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
reedal Posted February 5, 2017 Report Posted February 5, 2017 Just because the gain is set with DD-1 doesn't mean the music is clean or that the overlap he set it was is the same overlap of the music. You know which track he used for the DD-1? If he set the gain using the -10dB track, but the music has the bass recorded at -5dB, then he will be clipping the signal going to the subs. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
Walled_accord Posted February 5, 2017 Report Posted February 5, 2017 7 minutes ago, reedal said: Just because the gain is set with DD-1 doesn't mean the music is clean or that the overlap he set it was is the same overlap of the music. You know which track he used for the DD-1? If he set the gain using the -10dB track, but the music has the bass recorded at -5dB, then he will be clipping the signal going to the subs. Gain was set with the -5 db track and the music is mostly got160s. I've got a fairly good idea of what I'm doing but can not for the life of me find this smell.
reedal Posted February 6, 2017 Report Posted February 6, 2017 4 minutes ago, Walled_accord said: Gain was set with the -5 db track and the music is mostly got160s. I've got a fairly good idea of what I'm doing but can not for the life of me find this smell. Got160s and other rebassed music may be imprinted with a frequency that doesn't have any attenuation. It could also just be that the subs are still fairly new and you're just smelling the coil heating up the glue. Do the dust caps feel warm when the smell becomes noticeable? SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32
moh.vze.com Posted February 6, 2017 Report Posted February 6, 2017 Maybe subs are wired wrong. I'd take the subs out of the box and check the wiring to make sure the positive and negative wires are connected correctly. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Mitchaford Posted February 6, 2017 Report Posted February 6, 2017 Did you feel the subs? Are they warm? Hot? Cook an egg on the cap? 2008 VW Jetta Team Fi 12 CT 4000.1 CT 125.4 PWX 6.5 80 PRS EB Flex 2/0 Second Skin ^^^ Build ^^^
oldsoundguy Posted February 6, 2017 Report Posted February 6, 2017 Could be the amp your smelling. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/
Kraken Posted February 6, 2017 Report Posted February 6, 2017 Make sure youve got good wire going in, I recently ruined a alpine type r 12 by using shitty wire. make sure youre using true-to-size wire. are the subs d4 or d2 or d1? Alpine cde143bt/ Alpine ktp445u (4x45 amp) 2 Crescendo STS 1 (on alpine 4x45 on 2 channel mode) 4 Crescendo pwx 6.5's in front doors (Skar RP150.4) 1 Sundown zv3 12, SAE1500D. Box is 2.5 cubes tuned to 30hz.
Walled_accord Posted February 6, 2017 Report Posted February 6, 2017 2 hours ago, reedal said: Got160s and other rebassed music may be imprinted with a frequency that doesn't have any attenuation. It could also just be that the subs are still fairly new and you're just smelling the coil heating up the glue. Do the dust caps feel warm when the smell becomes noticeable? They are barely warm. They arnt that new but I've played them plenty so it shouldn't be that that they are new. It's happened before and it went away and now it's happening again 46 minutes ago, Kraken said: Make sure youve got good wire going in, I recently ruined a alpine type r 12 by using shitty wire. make sure youre using true-to-size wire. are the subs d4 or d2 or d1? All sky high wire. 8 gauge speaker wire and 1/0 power. It's 4 d2 sa 15s wired in series on each sub up to 4 ohm then all 4 wired parallel down to 1 ohm at the amp. 1 hour ago, oldsoundguy said: Could be the amp your smelling. Amp is in the trunk and the car is walled and completely sealed so I don't think it's the amp.
ChevyBoy95 Posted February 6, 2017 Report Posted February 6, 2017 Am I the only one who sees and issue of the box size for one? 18 cubes for 4 SA 15's? Also, if you set it with the -5dB track, you can still easily clip if you play anything above -5dB. Setting it with a DD-1 wont do anything for you if you dont understand what you are setting it to. Also, big thing... are they heating up fast on a particular song? (particular frequency)? SA's are know to be able to take 1000w pretty much all day long, so if you are heating them up enough to smell them , it would lead me to believe that he is clipping them pretty good at full tilt, so songs are probably above -5dB. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
