bluegmcjimmy Posted February 8, 2017 Report Share Posted February 8, 2017 Ok this is a noob question, how do you stall 3 amps or more safely? https://www.youtube.com/channel/UCWd1ShRnPbDG9ppgJKpumdA <---- show some love to my channel Alpine MRH-F255 (old school), sub channel not used Skar audio VX35-ST tweets in front (invest in them they are worth it) kicker zr120- nice underrated amp Powerbass s1204 subwoofer in a 1.75 custom slot ported enclosure tuned to 30hz Front doors Prv 6mb200s 8ohm Alpine type-e 5.25 in dash took a shave and a hair cut.....- not in use Rear doors alpine 6.5's model/series unknown but they are loud as hell Factory alt 3.5 farad cap, does the job for now. Deck is a pioneer mixtrax 700bt model And my baby my Pioneer EQ-6500 i got for 10.00 Back-up amps- Ma Audio 598i, kicker zr120, my highly under rated JBL LC-A502 1xx watt amp... On the side- Quantum tweets not yet installed Link to comment Share on other sites More sharing options...
reedal Posted February 8, 2017 Report Share Posted February 8, 2017 The same way you would a single amp, two additional or more times. SMD Tool Map https://www.stevemeadedesigns.com/board/topic/193176-smd-tool-map-new-november-2014/ Build log https://www.stevemeadedesigns.com/board/topic/197217-reeds-03-tahoe-hat-sqaq-singer-xs-shca-cockbox-80prs/?page=32 Link to comment Share on other sites More sharing options...
3vil Posted February 8, 2017 Report Share Posted February 8, 2017 Distribution blocks Link to comment Share on other sites More sharing options...
06RTCharger Posted February 8, 2017 Report Share Posted February 8, 2017 Distribution power and ground blocks. Fuse holders or distribution fuse blocks or circuit breakers(easy and quick way to cut power to ur amp, just flip the switch). Also i just learned its a good idea to have a relay to wire ur "remote" amp wires to, so they all turn on at the same time. Theres probably other ways to wire the "remote turn on wire" but thats the cleanest way i think. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted February 8, 2017 Report Share Posted February 8, 2017 A relay doesn't make them all turn on at the same time, a relay lets you use a secondary power source when the remote wire isn't enough. Not needed typically with 3 amps though. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
06RTCharger Posted February 8, 2017 Report Share Posted February 8, 2017 Oh, Secondary power, as in secondary remote turn on right? Can u run all three amps remote wires to the headunit? Link to comment Share on other sites More sharing options...
MrSkippyJ Posted February 8, 2017 Report Share Posted February 8, 2017 It basically acts as an automated switch. Remote wire activates the switch, battery provides +12v for amps to turn on. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
06RTCharger Posted February 8, 2017 Report Share Posted February 8, 2017 4 minutes ago, MrSkippyJ said: It basically acts as an automated switch. Remote wire activates the switch, battery provides +12v for amps to turn on. Ok im even more confused lol, ill go google it. Link to comment Share on other sites More sharing options...
MrSkippyJ Posted February 8, 2017 Report Share Posted February 8, 2017 Imagine a power wire from your battery that you connect to a switch, you flip that switch and it turns the amps on. A relay does just that, except the switch is engaged with a 12v source instead of your finger. Note: it's not a switch like you are used too, just using that to explain what it does. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69 Link to comment Share on other sites More sharing options...
