1 hour ago, nkrell11 said:
Tuned in I always wanted an XJ but I ended up with a WJ looking forward to seeing what happens with your jeep.
I checked out your build log, awesome stuff man!
I love all Jeeps, this XJ is my third, but its the first one I can really do what I want with.  I used to have a '99 WJ and it was a great rig, before that I had a ZJ for a number of years.
Builds:
Thank you very much I greatly appreciate it. Jeep builds have always just been cool to me yours will probably be done before mine.
Now that the doors are done I worked on making the tweeter pods and installing the crossovers.
For the tweeter pods I used a couple 1.5" PVC pipe caps.  I sanded them down to fit between the dash, A pillar, and windshield as well as possible.  I placed them so they are both pointed right at my dome light between and slightly behind the front seats.
Here is a test fit.
After they fit how I wanted I glued the mounting cups in and sanded everything down.
I painted them up with some spray on underliner, which kinda gave them a bit of texture.  I think they came out looking pretty decent.  Here is how they look installed.
The driver side crossover I stuck to the firewall under the dash,  the passenger side is behind the glove box, which you can see here.
Both crossovers are mounted using to high-strength velcro.
So far the front speakers are sounding great!  I'll dig out my measurement mic and see how the frequency response looks when I get the time.
Builds:
If this is anything like your box builds this should be good!
2010 Mazda 3s 2.5L
Pioneer DEH-X9600BHS
Knu OFC 1/0
SS Platinum AGM / XS Power XP750
Alpine PDX F-4 / Morel Maximo 5 + Coax 5
IA 10.1 / SSA XCON 12
I did some work on the factory power wiring.  The stock wire size is really small, 8 gauge at best.  Here you can see how it started out:
Where the negative lead grounds to the unibody is really poorly done.  I'm replacing everything with SHCA 4 gauge OFC.  We all know how the audio power cable game works, 4 gauge is really 2 gauge.  I get crimp on ring terminals from Amazon, 10 for $6. https://www.amazon.com/gp/product/B005V9UU0A
The hydraulic crimper always gives consistent results:
I put some adhesive heat shrink over the crimp, I just didn't take a picture of it.  I've found that if you avoid "car audio" specific products you can get pretty much the same stuff for a lot cheaper.  This is the heat shrink I use: https://www.amazon.com/gp/product/B01F2LG7G2/
For the battery terminals I used these military style ones: https://www.amazon.com/gp/product/B001QRTZR0/
I like them because its easy to bolt ring terminals to them and they don't stick up much where it would be easy for them to short out on something.  I think you get a more solid connection using crimp on terminals vs the battery terminal where you directly insert bare wire.
Here is the finished upgraded ground wire:
Before I bolted it to the unibody I got in there with the cutoff wheel and ground all the paint away around the bolt hole.  Should have good electrical conductivity now.  After I get everything tightened down I smear some grease on the battery terminals and the unibody ground to prevent corrosion.  I do this on every battery on the farm and I really works well.  It doesn't take much, just a thin layer to block out oxygen, you can hardly see it.
While I was working, this was the help I had:
Builds:
LOL, dat cat yo   But for real, I am glad you get to enjoy a build of your own.  Still looking good man, keep moving forward.  I know farm season is coming up fast!  Yes, hydro crimpers always consistent results.  =)
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
With the power transmission upgrades done I was able to put my temporary sub setup in.  For the amp I have a SP Audio 1,000 watt amp I got for $60 as a "surprise me" item from the Sundown Yard Sale.  $60 for a 1,000 watts, I'm not going to complain.
I mounted it under the front passenger seat, where it fits really well:
I spent hours cleaning that carpet and its still super gross.  At this point I can either live with it or tear it all out and replace, I'm going to just live with it for now.  With the floor mats in there I can pretend its not gross and at least I don't have to worry about trashing it any more than it already is.
For subs right now I'm rocking my Sundown E-10 tapped horn:
I'll probably play around with a couple different subs while I wait to build a dedicated enclosure for this rig.
Builds:
  • Who's Online   0 Members, 0 Anonymous, 1578 Guests (See full list)
