Help, need help with subwoofer enclosure
JoshDR
I am planning on building a sub box for a RX8, but since the trunk is small, my options are limited.
I might use either a single Rockford Fosgate P3 - 10" or 12".
But I've heard about 'port noise' and was wondering if my design would make the noise
I am using 5/8 MDF
The dimensions are in the pic:
Here's a good tip though it's not answering your question. I wouldn't use the RE Box Calculator. It's known to be inaccurate. Look up Torres. You can also use Winisd to plug in your box/driver parameters to generate some graphs that will give you a good idea on how the box will perform.
Will try it
But, do you have an idea about the 'port noise' ?
I read some forums about it and became skeptical
I am using 5/8 MDF
With about 29 square inches of port area you don't need to worry about port noise with the p312, however the calculator is inaccurate as stated, the real specs of the box you have posted are 1.5 cubic feet net @36.5Hz, pretty off.
Thanks alot, much appreciated
Do you think, I could extend the port length even more for lower tuning frequency ?
  • Who's Online   1 Member, 0 Anonymous, 1437 Guests (See full list)
