CAB 1600.1... Any guesses what happened?
1gggman1
One of my CAB amps is inoperative, I'm running 2 strapped at 2.66 ohm and my older amp... Bought in August 2016... is cutting out with a weird scratchy sound. If I slam the door of the car it cuts back on briefly the repeats the problem. It's still under warranty so I don't want to break the seal to see whats up. The amp appears to have the board shifted in the heatsink about 3/16" one way it had been like this for some time now and I had no problems... what do you think has caused this? I am not going to fix the amp myself... I'm just wondering what can be the possible cause?
Is it mounted to the box?
Pioneer 80PRS
Yes, sorta... the amp rack is 1.25" from the actual box to allow for the wire runs. I was hoping that this would insulate it from the worst of the vibrations.
What do you think... should it be sufficient?
I suppose I could put a center brace under the amp rack and isolate the amps with rubber bushings as well... this should help...right?
It's already attached to the box firmly at the top and sides, you can see this in the pics. Does anyone think all this extra bracing and isolation is necessary?
It's only at around 2500 watts or so at 2.66 ohms.
Looks like the side panel of the amp is pulling away from the heatsink of the amp
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Time to upgrade!
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
those amps are garbage. You shouldnt have cheaped out. Now you must pay the price of going cheap. If its still under warranty then get it replaced. Otherwise spend more on better quality.
  • Who's Online   0 Members, 0 Anonymous, 1561 Guests (See full list)
