How many runs of 2/0 would you do?
Hey all,
I just picked up a 2002 Tahoe, and I'll be running 4 SoundQubed HDC318s in a C-Pillar wall on two AQ 3.5ks @ 0.5 ohms per amp.
Electrical will be two 270A JS Ultimate alternators, 1 G78 AGM under the hood, and 2 or 3 G31 AGMs in the rear.
How many runs of 2/0 welding wire would you guys suggest? Also does anyone have easy suggestions for where to run it?
I'm currently thinking 3 runs each of + and - (6 total runs), and running them under the vehicle.
Any and all advice greatly appreciated.?
3 runs front to back is fine for only 540amps of alt. You'd probabaly be fine with 2 POS runs if they are OFC. 3 POS runs for CCA
It's a Tahoe, use the frame for grounds. 3 frame in front and 3 fame in back
2/0 welding is 1/0 car audio
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
I'll be running four runs of SHCA 1/0 from the passenger side underhood battery along the frame and up to the rear right behind the second row, running it through these
https://www.amazon.com/Daystar-KU20041BK-Universal-Firewall-Boot/dp/B0051ZG5K8
if you want the link for the second battery tray for the engine bay I can post that for you. You can fit a group 34 battery in that spot, and you'll have to remove the fender brace and cut the bracket that it bolts to.
Reedal always coming in clutch with advice. Yeah if you've got the link for a second battery tray that would be great to look at too.
It'll be 2/0 welding which I'm pretty sure is OFC.
I was planning to ground under the seats in the back, and haven't put much thought to grounds in the front yet.
If you try and do the "does this part match my vehicle" option and it says it doesn't, pay no attention to that. Those are the parts you need for the passenger side battery location.
Battery tray https://www.ebay.com/itm/191528781912
Battery clamp bolt https://www.ebay.com/itm/262455756309
battery clamp https://www.ebay.com/itm/371780949748
installation is pretty simple. Just unbolt the brace and cut the mounting bracket on the firewall side off. Then unbolt the metal tray that is between the coolant overflow and firewall, then bolt the new tray down, battery in, then bolt the clamp down on the side of the battery to secure it. I wouldn't use a battery that is taller than the XS D3400, but the 3400 is drop in fit.
Cut a hole in the floor in the back and ground straight to the frame. Tuned in.
Pioneer 80PRS
  • Who's Online   1 Member, 0 Anonymous, 3953 Guests (See full list)
