I have a bmw with the base stereo. Ive added a lc7 along with a 5 channel alpine amplifier. I have a lot of static with my volume down and my engine off, I've even tried upgrading to a DSP and if anything it makes my static or humming worse. After doing some testing i have found a problem. While playing a test tone i checked my signal voltage for all the wires on the lc7 coming from the head unit. As i understand signal voltage should be in the 5v-10v range. 3 of my signal wires read 6-7 volts and one signal wires reads 40+ volts. I know how to check signal voltage all i do is put multimeter in DC and test positive and negative speaker wires coming from head unit. Any idea why one signal wire would have so much coming through it?
21 hours ago, reedal said:
Signal voltage is AC, not DC......
Thank you I've realized this and I got confused by the Millie volts reading thinking it was volts . I've been trying everything to diagnose my main problem and I thought I had a lead. My main issue is when I disconnect all my rcas going from lc7 to amp, I can play music and still faintly hear it coming through my speakers, I'm pretty good but I'm no profession and I've never seen this before I have no idea what could cause it. Has annoying else ever experienced this ? It just seems impossible for the sgnal to travel with the rcas disconnected. It's  like the signal is traveling through air just enough so when you put your ear to the speaker you can hear it as long as the volume is up all the way
Try unplugging the rcas from the amp and see if it still does it. With the gain set high on the amp, it might be possible for the rcas to pick up an induced voltage from wires running next to it like the factory wiring or something. When you say static noise is it like an air sound mostly from the tweeters? This is caused by the gain being set too high. Is there anyone in your area with a DD-1? it might be worth buying one. The eq that I run has a pre amp in it so I can turn my gains way down low to get rid of this noise. Maybe the LC7 has an adjustable output, I don't know.
Pioneer 80PRS
i, too, have a bmw and had audio issues.  what year is your car?  also, where did you tap in your lc7?  I was running into turn on pop, engine noise, and static hiss with my 4 channel until i finally had the epiphany to look and see that even tho i had the base stereo, it's still amplified.  i bypassed the factory amp, and *poof*  all my issues disappeared.  wish i had thought of that before i threw money at it, but whatever.  so yeah, check where you tapped in for your signal wire to the loc, make sure it's before the amplifier, not at the speaker.  best idea would be directly out of the head unit.
The RCAs you have are likely of poor quality and the signal is escaping the shielding and entering the speaker wiring.
Can we get a better rundown of ALL of the equipment you're using?
How did you tune the LC7 and amplifier? How did you determine where to set your gains? Where are all of your ground wires grounded at? What RCAs are you using?
  • Who's Online   0 Members, 0 Anonymous, 1728 Guests (See full list)
