Ehxpired Posted September 13, 2017 Report Posted September 13, 2017 So I've installed new Morel Tempo Ultra 6.5 components (rated at 120 rms each), wired to a Rockford Fosgate r300-4 amp (75 rms x4) and for some annoying reason when i reach a relatively high volume the tweeters go all out on distortion and i dont know if Morel's arent actually good or my setup is just a mess ... help anyone?
MrSkippyJ Posted September 13, 2017 Report Posted September 13, 2017 How did you determine how much you can turn up the volume? How did you determine the gain setting? What about other settings? Crossover, boosts, etc? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
06RTCharger Posted September 13, 2017 Report Posted September 13, 2017 Id guess its ur settings/setup. Hopefully nothing is damaged, try to take it to someone that knows how to set all the settings, or take the time to read up on how to do it urself. Lots of info around here or just a quick google search.
ShadeTreeMechanic Posted September 14, 2017 Report Posted September 14, 2017 Your amp probably doesn't have enough power to play at that high level you are looking for. Learn how to set the gain correctly and bridge the amp to two channels for more power. 91 C350 Centurion conversion ( Four Door One Ton Bronco) 250A Alternator (Second Alternator Coming Soon) G65 AGM Up Front / Two G31 AGM in Back Pioneer 80PRS CT Sounds AT125.2 / CT Sounds 6.5 Strato Pro component Front Stage CT Sounds AT125.2 / Lanzar Pro 8" coax w/compression horn tweeter Rear Fill FSD 5000D 1/2 ohm (SoundQubed 7k Coming Soon) Two HDS315 Four Qubes Each 34hz (Two HDC3.118 and New Box Coming Soon)
Ehxpired Posted September 14, 2017 Author Report Posted September 14, 2017 On 9/13/2017 at 7:31 PM, MrSkippyJ said: How did you determine how much you can turn up the volume? How did you determine the gain setting? What about other settings? Crossover, boosts, etc? maybe i should really turn the tweets db down on the crossovers.. thanks for the reply man!
Ehxpired Posted September 14, 2017 Author Report Posted September 14, 2017 On 9/14/2017 at 12:39 AM, 06RTCharger said: Id guess its ur settings/setup. Hopefully nothing is damaged, try to take it to someone that knows how to set all the settings, or take the time to read up on how to do it urself. Lots of info around here or just a quick google search. yeah luckily nothing is damaged, i got the gains down a little until i finish saving up for new subs and amps thanks for the reply buddy
deathcards Posted September 14, 2017 Report Posted September 14, 2017 10 minutes ago, Ehxpired said: yeah luckily nothing is damaged, i got the gains down a little until i finish saving up for new subs and amps thanks for the reply buddy not picking on you just seen a few things and don't know your level of education in audio, just been around, half gain is not just down a little skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
MrSkippyJ Posted September 15, 2017 Report Posted September 15, 2017 2 hours ago, Ehxpired said: maybe i should really turn the tweets db down on the crossovers.. thanks for the reply man! how did you determine your headunit volume max and amplifier gain? F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Methodic Menace Posted October 28, 2017 Report Posted October 28, 2017 On 9/14/2017 at 7:05 PM, deathcards said: not picking on you just seen a few things and don't know your level of education in audio, just been around, half gain is not just down a little I damn near have my gain on my McLaren tweeters all the way down. TDH Methodic Menace ?
Soccerballzs Posted October 28, 2017 Report Posted October 28, 2017 you running these passive or active? What are your tweeters crossover points? http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/
