420ninja Posted November 5, 2017 Report Posted November 5, 2017 1991 mazda b2600i 4x4 2001 4.3 v6 700r4 as you will tell i dont like to mix match diff brands in my builds 32 cans of foam in the truck roof is 3 1/2'' thick foam in center with bracing goes out to top doors almost 2'' thick coverd with a 5/8 plywood the windshield has a 2'' 1/4'' thick 30'' long and the gap in center has another strip in it so 11'' in center is 1/2'' all screwed and stitch welded to cab the back wall is beat flat and is now 2'' thick foam coverd with the rest the sheet of 5/8 plywood then the entire gap of the cab from the roof to the pinch weld the entire ex cab is soild foam all around windows every hole then coverd in 62+sq foot of Knukoncepts deadner from the bottom of the windshield down is coverd no metal left bare entire floor walls everything inside doors outer panle are coverd as well also have a third alt that just runs the truck the two big alts only run the stereo so no diming headlights here lol the stereo is compleatley ran off 6 batts in rear and 2 big alts cd player and all also still running the stock alt that is on the 4.3 to run the truck nothing of stereo 2 mechman 270 amp alts running 15.3 volts 2 Skar 150.4 amps 1 mids/ highs other on 8's 1 Skar 4500.1 .5ohm 2nd one soon 4 Skar pro pax 6.5 at 4ohm 2 Skar 3.5 dome tweets 4ohm 2 Skar VD8'' at 2ohm in kicks 1 Seven speaker 15'' 5500 watt rms 130 pound 4'' coil 6.6cu net tuned 30 120sq'' port all wiring rca power wire speaker wire everything Knukoncepts 6 group 31 batts under bed were spare tire goes that uses the tire lift to raise and lower there is also 6 4/0 grounds to frame from batteries then 5 4/0 grounds from frame to bottom cab bolted the cab to ground plate inside 5 runs of Knokoncepts 4/0 from batts to back cab to fuse block
Ron36 Posted November 5, 2017 Report Posted November 5, 2017 We like pics 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
420ninja Posted November 5, 2017 Author Report Posted November 5, 2017 trying to figure out how to make them small enough to post cant get some to load
Skullz Posted November 5, 2017 Report Posted November 5, 2017 Can't help but think it looks like Marty McFly's truck. lol 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
420ninja Posted November 5, 2017 Author Report Posted November 5, 2017 best trick to make pic smaller to post
Wishuponasub Posted November 6, 2017 Report Posted November 6, 2017 Hosting site like imgur Sitting around waiting to be installed: 4 FI X 10 270 CES alt D3400/73ah lithium AA 3800.1 (2) AA 75.4
420ninja Posted November 6, 2017 Author Report Posted November 6, 2017 that is a skar vd8 in the 15 makes it look so small lol nominate me for SOTM
WalledSonic Posted November 6, 2017 Report Posted November 6, 2017 Dope build man! ..But those photobucket links will stop working after this thread gets enough traffic. Use any hosting site other than photobucket. Chevy Sonic Wall (4) 15's on 10k Build Log https://www.stevemeadedesigns.com/board/topic/209412-2015-chevy-sonicwall4-15s10klithiumlarge-case-hairpin-us-alts/ (4) Fi SP4 15's | (2) Ampere 5Ks | Active! | Arc KS600.2 & KS125.2mini | CDT Silk Domes | Silver Flute 8s | 240Ah JY | US Alts Jeep Wrangler JK (4) 8's in a 4th Order Build Log https://www.stevemeadedesigns.com/board/topic/209841-shadow-2016-jeep-wrangler-jk4th-order4-8sdc-35klarge-case-hairpin-us-alts/ IG @walledsonic
