5000-8000 watts rms electrical
So whats the plan OP?
IG @walledsonic
Plan is to run 2 18s on around 3000-4000 watts for daily with the ability to make 5000-8000 watt burp. If I can get away with an XS Power d3100 and a d1200 that's what id want to do. My 2600 watt amp and d1200 keeps the voltage above 11.8 at idle. If I need to upgrade the alt to suit my needs I'll do that but I'll need to rework my budget. I don't plan on keeping/using the system for more than a few months anyway.
Sorry to burst your bubble, but you will NEVER see 5000-8000w on a burp.
id say honsetly right now your voltage may be fine, but you arent getting a full 2600 rms out of that amp, unless your wired below the recommended ohm load, youre rising well above where the ratings are for that amp. realistically your are at the very edge of what a stock alt and single battery are able to where your at now. If you are planning on running 5k RMS, potentially, a H/O alt is a must. i ran an M3b with my stock alt and 3 banks of caps and couldnt go full tilt for 10 seconds without having to rev my engine. even then i couldnt play for more than 20 seconds. and thats 3800RMS, and i clamped it with a AMM-1
Fidelity
Built to Last
Team Sound Asleep
24Runner Build Log: http://www.stevemeadedesigns.com/board/topic/196657-24runner-sleeper-system-lots-of-fi-neo-dd-focal-new-video-w-juicebox-lithium/
2 x 12" Fi BTL N2 / 2 x 12" Fi BTL N3
2 DD M3b
Maxwell 2.7V 3000F Supercapacitors
Pioneer DEH-80prs
Focal P165 V30 components
Rockford Fosgate T-400.4
1 hour ago, Mr. Clapp said:
Guess we'll see
It isnt a guess we will see. If you are wired to lowest manufacturer recommended load (1 ohm or 2 ohm depending on the version), unless you have zero rise (impossible with a subwoofer), you wont get that number. Probably 3kw or so.
I'm just planning everything out, heck it might be a 30Kw system I haven't decided on what I want and how I wanted to do it yet. But yeah I see what you're saying about box rise, not really worried about it yet.
"Dont fly too close to the sun, Icarus. You'll burn your wings" haha
IG @walledsonic
  • Who's Online   1 Member, 0 Anonymous, 1131 Guests (See full list)
