Laptop program to measure frequency levels?
Hey guys. Wondering if anyone can help me out. Im helping my buddy put some music in his truck n he doesnt have the budget for a dsp for the time being...
My question is if there is a program that i can download onto my laptop that will measure frequency levels so i can help him accurately adjust his EQ, xover points, etc... Any help is much appreciated! Thank you in advance!
Well, that's the issue. Measuring frequency levels of a song wont help in the end. Most of the EQing that needs to be done to make a system play flat needs to be done with an RTA to adjust the sound in the cabin of the vehicle where it will be heard.
Thats what im tryn to figure out. Maybe i didnt word it very well. I basically wanted to get a program to DL on my laptop, hop in, hook a mic up to it n play different frequencies, songs while i adjust the EQ by referring to the peaks n valleys that are displayed thru the laptop.
If your looking for something on the cheap cheap, TrueRTA has freeware software that you can use, but also a paid version.
https://trueaudio.com/rta_abt1.htm
Sadly the RTA will be very dependent on the microphone used, if you use a cheap mic your results will not be the best since a cheap mic will not have a good frequency response.
I probably wouldnt use a cheaper mic than this if you want any kind of realistic results.
https://www.parts-express.com/behringer-ecm8000-measurement-microphone--248-625
Like others have said, the mic is the hard part.
Here are a couple other mic options:
https://www.parts-express.com/dayton-audio-umm-6-usb-measurement-microphone--390-808
https://www.minidsp.com/products/acoustic-measurement/umik-1
Once you have a mic the software is the easy part.  I use one called Room EQ Wizard (REW), its free and there is lots of info out there on how to use it.
Builds:
Thank you for the reply guys! I saw one that has an android option n Ive saw people on Youtube using their phones for SPL. Is there anything i can use to measure using my phone?
appreciate it! I dowloaded this last night n watched a video on it. Seems to be easy enough to understand thati can prob figure it out!
tons of stuff out there, the big thing is how much money you really want to drop. figure you'll need to at least spend $150 to get a decent RTA setup. Audiocontrol makes a calibrated mic for iOS. A ton of industry guys use a windows based laptop for REW (Room EQ Wizard) with a calibrated mic like the UMM6. Other industry guys that do a lot of OEM integration use Phonics PAA3 and PAA3x. I personally use REW with the UMM6.
if nothing changes, nothing changes
You don't know what you don't know, till you don't know
