Power handling
BassMunky
So I just recone my subs how do I know the rms? It aa chaos recone with psi soft part 12 in .
RECONE KIT - 28 (d 19/11u) 82mm XL FW voice coil - D2.0 1 soft +1 stiff Dual sewn leadwire Chrome push terminals (clip for dual leadwires) 12" HD Cone w/ wide roll surround 6" Poly dome w/ PSI logo
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
And how much money did you save going with PSI rather than Fi?
IG @walledsonic
A 3" 82mm fw aluminum coil is pretty long but the motor is usually what does most of the cooling.
That being said, you might be able to give a longer coil more power but still, you'll need to see how it thermally holds up with that motor.
Soo yeah how i check the ohm of the sub if I wired it correctly to 1 ohm. I put it on the ohm on my voltmeter and it reading it weird on the 200 ohm . I using a Sears craftsman multimeter.  After playing the subs for a 1/2 hr the cone felt a lil warm is that ok. No smell? Rf 1500 bdcp  amp
  • 1 month later...
