xxdrwhamxxx Posted March 17, 2019 Report Posted March 17, 2019 Looking for opinions on whether or not to use a capacitor with my setup. Equipment as follows: pair of JL 12W3 D4's and a pair of RF 500X1D's one per sub. The load on each amp will be either 150W @8ohm or 500W @2ohm, I'm leaning towards the 150W since 500W is twice the continuous power rating on the subs. I currently have the subs wired to one amp and I have a cap. I also have a deep cell batt and a 105amp alternator. When I split by adding another amp, should I continue to use cap? It has served me well up to this point, providing quick burst of energy for the lows, quicker than the batt could. ( I tested the sound before cap and after) I'm aware there are many opinions on the subject but since I'm splitting the system 2 amps wont work as hard as 1, (maybe?) Thoughts?
bmwking Posted March 17, 2019 Report Posted March 17, 2019 no. use a battery. unless you're doign a bank of maxwell caps, a capacitor is trash. your alternator and 1 agm battery is more than capable of handling 1000w
Dragonsyph Posted March 18, 2019 Report Posted March 18, 2019 Ya if it's not something like 500+ Farads then toss that cap in the trash, only thing its good for is a filter. Like above said, best bet is a good AGM. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA
xxdrwhamxxx Posted March 18, 2019 Author Report Posted March 18, 2019 Thanks for the follow up guys. Agreed, gonna get rid of the cap. 1 more question, I have the option for wiring 500w x1 @ 2ohms or 150w x 8ohms (Subs are DVC 4ohm) I'm thinking 150w should be plenty. My current setup has 75w per sub and they sound pretty good. Due to the age of the subs I'm concerned with overpowering even if dialing the gains back. Well, maybe that's the answer. Twice the RMS power but still well below sub RMS rating, no brainer I guess. And less likely to damage the subs.
bmwking Posted March 18, 2019 Report Posted March 18, 2019 3 hours ago, xxdrwhamxxx said: Thanks for the follow up guys. Agreed, gonna get rid of the cap. 1 more question, I have the option for wiring 500w x1 @ 2ohms or 150w x 8ohms (Subs are DVC 4ohm) I'm thinking 150w should be plenty. My current setup has 75w per sub and they sound pretty good. Due to the age of the subs I'm concerned with overpowering even if dialing the gains back. Well, maybe that's the answer. Twice the RMS power but still well below sub RMS rating, no brainer I guess. And less likely to damage the subs. sounds like you answered yourself
BassMunky Posted March 18, 2019 Report Posted March 18, 2019 Suggestion on Maxwell cap from ebay ? And how many? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
kalilac619 Posted March 18, 2019 Report Posted March 18, 2019 23 minutes ago, BassMunky said: Suggestion on Maxwell cap from ebay ? And how many? As many as you can fit 2000 Suburban 6 runs of 2/0 12 JBL Pro audo mids ,6 timpano audio tweets and 1 Prv compression horn per door 475ah of yin long LTOs Triple 370 Amp Autotech Alts mids amps 2 Crescendo Skyway 3ks compreesion horn amp crossfire 800.4 Tweet amp Crossfire 2000.4 sub amp: 4 Crossfire XT 8ks Subs: 8 18 in Crossfires in a 4th order Best Scores at events… 163.5@38hz DBdrag sealed on the dash… 164.3 outlaw…162.9 Meca headrest
BassMunky Posted March 18, 2019 Report Posted March 18, 2019 What size? Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX And put a sealed enclosure in your trunk cut a hole in your deck and call it ported
corey0928 Posted March 19, 2019 Report Posted March 19, 2019 2 hours ago, BassMunky said: Suggestion on Maxwell cap from ebay ? And how many? Do you understand the nature of super capacitors? They aren't a battery replacement for daily applications. Ideally you want your alternator(s) to supply the majority of the power and the batteries to be there for reserve if you are idling or you want to play while the car is off. But if you are looking for information you should make a new thread and keep this one on topic. OP can you try to sell your amps and find one that will match the wattage of the subs at 1 ohm wired together? Would be much easier and more efficient than under powering those subs.
k58.cross Posted March 19, 2019 Report Posted March 19, 2019 Seems like nowdays people only really use caps for burps in SPL comps. Difference between cap and battery is that a cap discharges and charges much faster, so good for those hard and fast BUUURRPPP uses. But on a daily driver, I think you're way better off just supplementing with batt power.
