Ditched SPL, trying infinite baffle SQ(L) in new build??
9 minutes ago, ToNasty said:
It loads to the outside of the car if the floor is cut out.  Basically somewhat exposed to the elements
You sure you wanna do that?
Water splash up against that?
39 minutes ago, ToNasty said:
I'm an ae type of guy. But I do have a question.  Is the floor cut on the baffle? Because If not than that's not infinite baffle
38 minutes ago, AaronT said:
Dude that looks awesome.
Can you explain the box to me?
I know it's IB, just don't understand the loading aspect of that design. Also why are you cutting a hole in the floor pan?
I have that body style escape as well they are unusual little trucks
So, yes. The floor pan will be cut, i figured an opening 15"x15" would be good enough for them to breath through the bottom. as far as mud & water, i picked up a waterproof membrane that lets air pass through without all the crap. i wouldnt powerwash the underside lol but it seems good enough for driving in the rain and such
Vehicle: 2002 Ford Escape
Electrical: 275A Singer, 160ah XS/Yinlong lithium, 2,000farad XS Supercaps
Head Unit: Apple iPad Hi-Res Passthrough Topping d10s
Speakers: {ACTIVE} - (4) Arc Audio RS 6.0, (2) Arc Audio RS 4.0 & (2) Arc Audio RS 1.0
Sub Stage: (2) TC Sounds LMS Ultra 5400 18"
Amplifiers: ARC Audio - (4)4200SE(comp modded, (2)4000SE
Processing: Helix DSP Pro W/ Dash Mounted Director
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Sup dudes, so my 4000se amp isn't working.. well it is, just have 97v DC across the speaker outputs. Contacted Arc & it's passed end of support because it's an older SE model. Pretty sure they're gonna take a look at it and see if they can fix it though. Their customer support is top notch from every dealing I've had with them so far, so I hope this turns out just the same. So honestly, if it's not fixable, probably gonna scrap the project 😐. In the mean time, I've wrapped a few more pieces, added some more Plexi lighting in the front, felt it needed something & some odds n ends wiring.
2019-11-05_06-02-422019-11-05_06-02-512019-11-05_06-03-072019-11-05_06-03-222019-11-05_06-02-012019-11-05_06-03-432019-11-05_06-01-362019-11-05_05-51-272019-11-05_05-52-152019-11-05_05-51-122019-11-05_05-51-582019-11-05_05-52-572019-11-05_05-53-03
6 minutes ago, jnasty said:
Sup dudes, so my 4000se amp isn't working.. well it is, just have 97v DC across the speaker outputs. Contacted Arc & it's passed end of support because it's an older SE model. Pretty sure they're gonna take a look at it and see if they can fix it though. Their customer support is top notch from every dealing I've had with them so far, so I hope this turns out just the same. So honestly, if it's not fixable, probably gonna scrap the project " src="https://twemoji.maxcdn.com/2/72x72/1f610.png">. In the mean time, I've wrapped a few more pieces, added some more Plexi lighting in the front, felt it needed something & some odds n ends wiring.
I know where you can get a mint 4200 with upgrades for 600 bucks :)
That's a deal right there! I would've gotten that in a heartbeat before i grabbed the 2300 & 2075. I want my 4000 fixed though 😖 i did contact theamplab but they said they cant fix this model though
1 hour ago, jnasty said:
That's a deal right there! I would've gotten that in a heartbeat before i grabbed the 2300 & 2075. I want my 4000 fixed though " src="https://twemoji.maxcdn.com/2/72x72/1f616.png"> i did contact theamplab but they said they cant fix this model though
I can put the message in if you want it
