what is your clamp meter reading before it hits clipping? do you have any impendance rise coming across the positive side of the power wire coming from the battery to amp? was the voltage measured during testing done at the battery, amp, or vehicle dash meter?
Clamp meter gets up to about 8.5 amps. I'm not sure about the impedance rise yet. As for the voltage it was measured  at the amp and at the battery
so did you test the rca output to the amp?  set your max sub output using the scope to target your max volume b4 clipping then set the amp?
 thats the flow    set your clean signal then amplify that signal
