SesameCreeps Posted January 29, 2020 Report Posted January 29, 2020 Can someone please explain to me why amps recommend fuses that are smaller than what they draw. Like a 3000-3500 watt amp will recommend a 300 or 350 amp fuse but that amp pulls almost 400 amps. How doesnt the fuse blow all the time?
Scotnemily Posted January 29, 2020 Report Posted January 29, 2020 A 300 Amp fuse wont typically blow instantly at 300 amps. If it does chances are it is faulty. It takes some time at 300 or more amps to pop the fuse. (using your numbers.) like wise that 3500 watt amp is not drawing a constant 400 amps. If it were and you had it on a 300 or 350 amp fuse it would pop after some time has passed. Someone else might Chime in with more detailed info, but hopefully this helps
SesameCreeps Posted January 29, 2020 Author Report Posted January 29, 2020 ya that sounds right. the 400 amps is at full tilt volume correct? or almost like a sign wave signal not music?
Dragonsyph Posted February 2, 2020 Report Posted February 2, 2020 Fuses are for the wire used I’m pretty sure. ♦ Sundown NSV4 18" + Sundown SALT-4 Baby ♦ MechMan Elite 370a + XS3100 - XP3000 ♦ SHCA 1/0 OFC(blue) + SMD Fuse Holders(blue) ♦ Pioneer AVH-2440NEX + SHCA Pro RCA
Ron36 Posted February 2, 2020 Report Posted February 2, 2020 31 minutes ago, Dragonsyph said: Fuses are for the wire used I’m pretty sure. U are correct fuses blow to keep your wire from melting or starting on fire and blowing your amp. 2022 Ford Maverick on 22’s Skar SK1500.1 on 4 Skar VD-8’s Mids Sundown Super tweeters, Skar TX 6.5 components on Skar SKM400.4 LC2 for audio control , XS Power D680 XS Series Extra Battery
Kyblack76 Posted February 2, 2020 Report Posted February 2, 2020 The high fuse rating, is best case. Burp, at lowest impedance/ohm load, and such. Even wired at 1ohm, your not pulling full current on music. Your probably pulling about half of that. SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
