like i said, email dan [email protected]  for more info. he has been running them for a few months now and should be able to give u feedback on them. he knows his shit, so u can trust his judgement.
from what i heard, the amps can take a beating...check this thread out..
http://video.snoopdan.com/teamdailyforum/v...wtopic.php?t=18
i likes me some audio stuff...
the old ones take the beating so far, i would have got a warlord, but im just waiting a while before i get a new amp
well either that or get them from his US distributor.
I dont like that i dont know much about them performance wise, or that the companies longevity isnt there yet.  I dunno i guess im just thinking that i dont wanna spend 1k on somethign that maybe 8 months down the line the company doesnt exist (not saying that will happen here)
nah this is a diff amp the warloard not the conq
specs are below from the aa site
FEATURES
Digital Class D Linkable Mono Block Amplifier
Daisy-Chain Through Output RCA
Dual MOS-FET PWM Power Supplies
Stable into 1 ohm and 2 ohm Parallel Amplifier Connection Availability
24 dB Low Pass (LPF) Crossover Variable
18 dB Bass Boost Equalization Control Variable
180 degree Variable Adjustable Phase Shift
24 dB Subsonic Filter Variable
****Selectable Switch for MASTER and SLAVE operation****
Speaker Short, Over Current, Thermal, and DC Portection Circuit
RCA Line Input and Line Out
Heavy Duty Cooper Layer Double Sided EPOXY PCB
2 x 0 Gauge (AWG) Battery Input Connectors
100% QC Testing and Warm UP
Efficiency: 86% at 4 ohm, 100hz
Operating Voltage: DC 10V ~ 18V Power Input
Damping Factor: Better 350 into 1 ohm
Wired Remote Bass Gain Controller with 5 Meter Flat Cable: Optional
SPECIFICATIONS
RATED POWER OUTPUT
RMS Power 1 ohm (12.0V)-------------------------------- 3400W x 1CH
RMS Power 1 ohm (14.0V)-------------------------------- 5000W x 1CH
RMS Power 1 ohm (16.0V)-------------------------------- 5900W x 1CH
RMS Power 1 ohm (18.0V)-------------------------------- 7500W x 1CH
2 SAME UNITS PARALLEL LINKED
RMS Power 2 ohm (14.0V)-------------------------------- 9900W x 1CH
RMS Power 2 ohm (16.0V)-------------------------------- 11800W x 1CH
RMS Power 2 ohm (18.4V)-------------------------------- 14900W x 1CH
Signal to Noise Ratio ---------------------------- >100dB
Low pass frequency crossover ---------------------- 35Hz~300Hz
Subsonic filter ------------------------ 10Hz~60Hz
Bass boost @ 45Hz------------------------------ 0~18dB
Phase Shift Control -------------------------------- 0~180 degree
Frequency Response ------------------------------ 10Hz~350Hz (+/- 1dB)
T.H.D. @ 4ohm ------------------------------ <1.0%
Efficiency @ 4ohm -------------------------------- 86%
Fuse rating ------------------------------ 250A x 2 (External Type Fuse)
Input Sensitivity ------------------------------- 200mV to 6V (+/- 5%)
Dimensions ----------------------------- 270(W) x 65(H) x 620(L) mm
The above specification shall be modified by manufacturer for improvement without prior notice
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
that's a lot of power
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 19071 Guests (See full list)
