Im in the middle of a box design atm andi dont have the ports in front of me they are in transit but does anyone know the
cutout diameter i need to flush mount them with the flange on the 4" model
http://www.partsexpress.com/pe/showdetl.cf...tnumber=268-352
ports will be inside of box mounted on outer wall of box i just need to know what size hole i need to cut as i know its not 4" and i havent used these in a very long time.
any helps greatly appreciated , and even a hardy fuck you accordman is also welcome.
thanks in advance.
fuck you accordman
DC.jpgDC POWER
i needed the cutout but found it
6.25" cutout diameter.
7.25" outer diameter.
I know because I've used lots of these and I've emailed PSP and they told me the same.
needed that cutout diameter for the jasper jig so when i mount it it will be flush
thanks for that outer dimension though as it puts more confidence in what i found
its old i just put it back lol
i think im going to continueally change it to shit that makes me laugh
kinda late now, but for future reference if you forget the size ever, or wondering about a different size psp.
the mounting diameter/cut out is the size of the small flange/flare, and just measure it.
edit, I just measured one of my 4 useless ports, and the measurements above are correct, so you can be 100% sure now :)
Edited by audiofanaticz
  • Who's Online   0 Members, 0 Anonymous, 5220 Guests (See full list)
