I have two Fi q's dual one ohm wired at 1 ohm, and one T20001bd. The amp at hi volumes goes into protect mode at hard bass notes. It doesn't stay in protect mode it just does it for a second, but throughout the whole song. I can strap the subs at 4 ohms but I'll be under powering the subs big time. Its annoying and I would really like to know if theirs a fix for it.
you do have the dual 4 subs right?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
I would put a meter on the amp and see what the impedance is while playing. Im not sure if I can recall impedance lowering on a sub ever. I have only heard of impedance rise. It could be going into protect from lack of sufficient current/electrical issues.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
what is your electrical system look like? Maybe your starving the amp for power.
Follow my Tweet (Twitter)
none of their subs come in dual 4.
I got a stock bat and a Irraggi 300 amp alt. The big three Steve Mead style, and multiple runs of RF 0/1 wire. I basically copied what you did to this car (wire wize).
SMD
Why do you have a 300amp alt and a stock battery get a some kinetik, powermaster, or stinger.... You need a high performance battery as much as a high performance alt.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
Will do. Is this the reason for the protect cutting on?
ETA: I was told that the amp only draws from the alt, while the car is on.
Edited by m4a3master
could very well be the reason....for your battery could be discharginq quicker than the alt can charge it ;)
Eclipse cd7000
Umm does your car disengage the battery while its running? That statement is false. the amp is going to draw through the batteries while its running also. Your electrical is only as strong as its weakest componant... this being your battery.
Scientia est Vox
  • Who's Online   0 Members, 0 Anonymous, 3030 Guests (See full list)
