TJ_Jeep Posted August 6, 2008 Report Posted August 6, 2008 Well if you know me when im my jeep ill play my music pretty loud but after a while the amp for my subs will get really hot and turn off which i can understand that but i was looking for like a fan or something to help cool it down any help would appreciated Quote Vehicle:1998 Jeep Wrangler 4.0 I6 with Cherry Bomb and Cold Air Intake, Speakers:5 1/4 Pioneers in front and back Deck: Jensen DVD In-Dash Amp: Lanzar Opti-Drive 2000w Subs: 2 Boss Chaos Edtion 1000w max (500wrms) Rubber: Nitto Grappler 35 x 12.50 Fun Things: Cobra CB with PA speaker to piss people off =] If the listening level is too loud, then your not deaf enough =]
roscoe1129 Posted August 6, 2008 Report Posted August 6, 2008 Unless they are isolated from "fresh" air, a fan isnt going to help. If they are in an enclosure almost any fan will help. I would find a squirrel cage style fan as I have found them to move the most air. If budget is an issue I would go with just a regular fan simular to the ones used in desktop computers. Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
TJ_Jeep Posted August 6, 2008 Author Report Posted August 6, 2008 Unless they are isolated from "fresh" air, a fan isnt going to help. If they are in an enclosure almost any fan will help. I would find a squirrel cage style fan as I have found them to move the most air. If budget is an issue I would go with just a regular fan simular to the ones used in desktop computers. yea thats what i was thinking about an computer fan i have the amp under my seat but the seat is like 5 inchs off the ground so its not suffocated Quote Vehicle:1998 Jeep Wrangler 4.0 I6 with Cherry Bomb and Cold Air Intake, Speakers:5 1/4 Pioneers in front and back Deck: Jensen DVD In-Dash Amp: Lanzar Opti-Drive 2000w Subs: 2 Boss Chaos Edtion 1000w max (500wrms) Rubber: Nitto Grappler 35 x 12.50 Fun Things: Cobra CB with PA speaker to piss people off =] If the listening level is too loud, then your not deaf enough =]
Amalan Posted August 6, 2008 Report Posted August 6, 2008 why wouldnt a fan help if the amp is in "fresh" air? i would assume it would work how a laptop works have a fan bringing in "colder" air and another fan extracting the heated air. Quote
roscoe1129 Posted August 6, 2008 Report Posted August 6, 2008 why wouldnt a fan help if the amp is in "fresh" air? i would assume it would work how a laptop works have a fan bringing in "colder" air and another fan extracting the heated air. not a good example a laptop is enclosed he said his seat is 5" off the ground so it may help a little but not like if it was encased. Quote Some people need a sympathetic pat... on the head...with my hammer Scientia est Vox "In Nomine Patris et Filii et Spiritus Sancti" DONT BE AFRAID TO USE THE SEARCH BUTTON!!! SMD SUPER BUYER/SELLER
TJ_Jeep Posted August 6, 2008 Author Report Posted August 6, 2008 not a good example a laptop is enclosed he said his seat is 5" off the ground so it may help a little but not like if it was encased. so what would be my best thing to go with Quote Vehicle:1998 Jeep Wrangler 4.0 I6 with Cherry Bomb and Cold Air Intake, Speakers:5 1/4 Pioneers in front and back Deck: Jensen DVD In-Dash Amp: Lanzar Opti-Drive 2000w Subs: 2 Boss Chaos Edtion 1000w max (500wrms) Rubber: Nitto Grappler 35 x 12.50 Fun Things: Cobra CB with PA speaker to piss people off =] If the listening level is too loud, then your not deaf enough =]
Boon Posted August 6, 2008 Report Posted August 6, 2008 You probably want a crossflow fan mounted in a kind of cool way, but you could just slap a couple of regular fans on the amp wherever it gets hottest and it'll still help cool it enormously. Alternatively you could find out why it gets so hot in the first place... Quote 10.x volts fo' life!
TJ_Jeep Posted August 6, 2008 Author Report Posted August 6, 2008 You probably want a crossflow fan mounted in a kind of cool way, but you could just slap a couple of regular fans on the amp wherever it gets hottest and it'll still help cool it enormously.Alternatively you could find out why it gets so hot in the first place... yea i might just put 2 on each side, im guessing the reason it gets so hot is because i do play very it loud for a long time or there might be something wrong with the amp it has had 12v on one side of the speaker output but its never showed any problems Quote Vehicle:1998 Jeep Wrangler 4.0 I6 with Cherry Bomb and Cold Air Intake, Speakers:5 1/4 Pioneers in front and back Deck: Jensen DVD In-Dash Amp: Lanzar Opti-Drive 2000w Subs: 2 Boss Chaos Edtion 1000w max (500wrms) Rubber: Nitto Grappler 35 x 12.50 Fun Things: Cobra CB with PA speaker to piss people off =] If the listening level is too loud, then your not deaf enough =]
wL<3bass Posted August 6, 2008 Report Posted August 6, 2008 yea i might just put 2 on each side, im guessing the reason it gets so hot is because i do play very it loud for a long time or there might be something wrong with the amp it has had 12v on one side of the speaker output but its never showed any problems Who puts the power wire into the speaker outputs? They are labeled. Quote Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
99vic Posted August 6, 2008 Report Posted August 6, 2008 (edited) i have a 12v computer style fan from radio shack i paid $19 that worked miracles in my trunk with out the fan my old amp would cut off after 30 mins of playin hard i added the fan and it was fine i have also used the large stinger fan that also worked fine i paid 30 or so for it, http://www.darvex.com/miva/merchant.mvc?Sc...duct_Code=SGJ78 Edited August 6, 2008 by 99vic Quote REST IN PARADISE BIG RICH (Sqmonte) never forgotten Why do you guys ALWAYS dispute on NUMBERS????? It's such a played out argument, so fucking annoying.... It's 12 fuckin 15's.... It's louder than you... Shut the fuck up... /Rant I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!dont buy from knowledge he will scam you. http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
