just buy a capasitor and youll be fine
Okay first thing.... don't offer advice if you don't know what your talking about, 2nd its spelled capacitor...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
as long as the alt is over 100 amps then i believe a capacitor would work fine. if ur prolly gonne upgrade later then go ahead and get batteries and a new alt. if not dont worry bout it. im runnin 1400-1500 wrms wit a 1.2 farad cap and a 130 amp max alt. my voltage only goes down to about 13.1 which isnt horrible for bein all stock.
so in this situation i believe a capacitor would work fine. not everyone needs to add extra batteries
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
yeah but wouldnet a smaller battery work more effecent than the cap?
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
if the alt can charge that battery the front battery and run the amp then yes.
i just dont like people sayin caps suck cuz they dont. in his situation i think a cap would do exactly wut he wants it to
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
true a cap does the job mine works okay!
ok think of it this way. you need to charge the cap correct? Once it is drained or current is pulled from it it will need more juice correct? Well what happens then? the alternator has to charge it along with supply the necessary current to the rest of the items that are in need. You just created more current draw then you originally had. Same thing with a battery the only good thing is that you have a bigger reserve to pull current from before the its noticeable. if you are advanced far enough to have these issues then you really should consider running a bigger alternator that can power everything sufficiently.
Dont bandaid your electrical when it needs stitches!!!!!!
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Do we have two of the same person in here? Ya'll are from the same town, hope you don't go startin' no bull shit like the other guy did. You definitely want to do the big 3 whether you get another battery or not. It helps everything.
so can u find what I need like links cause i have no clue what to do
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
I recommended him here ill keep him under control lol.
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
