I don't care how much it flexes, NO ONE IS SITTING ON MY CAR!!!!
to hit 150 dB, I would let 4 fat b----es sit on the windshield, the trunk and brace my doors for me!
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
Ill sit up there ......burp ....then im in Gary's lap ....
LoL :friends:
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
where your seat folds down there ductape that flap down
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
^very possible that could help since its so close
because you are using aeros, im going to guess that u should try smoothing out the surface on the back of ur seats somehow with thin metal, hell kitchen/bathroom vinyl might even work.... try to create smoother surfaces right around the port and maybe even between the cabin and trunk since it is a contriction and there could be some odd pressure build up there... think of an spl only vehicle... u dont see much carpet for a reason... painted: vinyl work, fiberglass, concrete, wood, are the norm... this is if you are really looking for tenths
support your ports close to the outer flares... who the hell knows man... ud be surpised
use the same color tape...haha
start thinking of little things like that
Edited by decafcappucino
i was also thinking next to the far ports put some 45s on those to direct the air into the cabin better
crude drawing but i think it gets the point across
Posted Image
R.I.P!
(Nov-29-2009)
92 explorer
current build
Gary what if you make a baffle board for between the back seat and trunk. Seal that area up and only let your ports come through the baffle.
If you can, get the front of the baffle flush with the ports and also the hole you cut out for the port to go through flare the wood around the holes you cut for the ports.
Now if your wondering, well if I do that then my subs will be sealed off. Don't worry about that yet. Go ahead and do the termlab testing.
If you don't like what you see, go ahead and take the rear speakers out of the rear baffle and let the sub bass come through. Test again.
If no luck man, yank it all back out.
You know the game Trail and Error. Its the only way.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Befroe you take out the back speakers. Mount a piece of 3/4 MDF directly above subs on to the car. One of those fun upside down on your head jobs.
Now what that might do is #1 give your subs a very solid area to reflect against and maybe will help push more pressure natural preasure on your sub cones that inturn may help the preasure comming out of the ports.
It will also give you a solid area that your bass is not flexing that you can unload on to. If you can resin the front of the wood that the subs will be unloading against it would help alot too.
