I <3 installs with 30+ subs.
x2 :) build is lookin good. i've thought about doing a tunnel with mine. havent tried calculating airspace or anything tho to see if it will work space-wise. lookin forward to seein it finished :)
It won't be long guys. I'm just waiting on my amps. Here's my plan for tomorrow:
1. Install subs and wire them
2. Install alternator
3. Hook up all power and grounds
4. Build my amp rack
-Still a little confused on this one...
I think the amps are gonna have to go in the front. If I make space for them in the back, I'll lose a lot of air space. I think I'm just going to build a box around them in the front on top of the batteries and have a plexiglass face on the top so you can see the top one's symbol...
The positive to this (no pun intended) is that they'll be very very close to the bank but the negative is that they'll be exposed to potential pressure...
I could also run a little cooling line from my A/C into the little box so there's no heat build up (?)... I'm still working on this one.
Any ideas for the amps?
Need an install? Hit me up.
[email protected]
Tip: do alot of braces on the inside of the tunnel... it will flex.
Looks alot like my old build.... Good luck with it... have fun wiring it, I did.
Posted Image
Posted Image
Dodge Magnum with custom 300c front end, laid out on air bags
*4) 12" Cadence Daytona walled
*1) AudioQue 20k
*270a DC Power Alt (Dual coming soon)
Oh no, here he goes again! :D
I gotta see this!
I'm skeptical regarding the airspace for that many subs being available in a PT, but you are off to a great restart.
There are members here with 20+ subs that can help you with advice, Assman, Galactic, Exposport.....
PTCary
2003 SMD PT Cruiser
2011 Honda CBR 250R
2010 Mazda 3i Sport
MY BUILD LOG
thought i was doing good with 8 12's, going to have to go big to keep up with the guys around here. Looks great, take your time and it will be right the first time.
How many cubes you squeeze out of that PT for the box, it seems like it is kinda small for those subs but cone space plus power will almost always get nasty loud.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
