14cuft before displacement
12cuft after subs and port
whats up first thing love you work and you web site keep the crazy installs coming love them.
i know you are busy but i need a little help please with a port design. I have used the calculators on the the net. Carstereo.com Came back with some for a sloted port
2 18"btls
32hz
7"height
26"width
15.75"Length/Deep
is this going to work this is the last of my build need some advice and will take any info
Thanks and once again love you work
I don't know if anyone but Meade can answer this, but if so have at it.
I am getting ready to buy the 4 alt bracket for my 01 tahoe from Dominick Iraggi, but I remember from your build you had problems initially. Is there anything you would recommend I specify before buying- because I simply don't have the skills to rig things like you did :blink::) . Also, I don't have any pre-exisiting wiring for a 2nd alt, so unless the kit comes with specific directions and/or wiring I'm not sure what to do. I've searched for info on installing multiple wire alts, and there just isn't much out there.
Thanks again, I posted in the electrical section but this is sort of vehicle/part specific.
tejcurrent
XS Power
T3
The 3 smaller wires that control the alt (?) can be wired in parralel with the other alts. (I would think that's how it'd be wired?)
But would I need to buy new harnesses to plug into the alts?
I know he said he got bearings for the bracket a little down the road that made a huge difference? So basically the kit should come with everything I need then?
thanks for the quick reply btw.
tejcurrent
XS Power
T3
  • 4 weeks later...
Shit, I dunno. Don't know if Dom includes the harnesses or not either. I guess if not, make em I guess....
Just splice the wires from the harness to the other alt.
  • 3 weeks later...
Hey wats up steve meade. i need some advice man. i was previously going to buy 2 btl 18's fully loaded a iraggi 200 amp alt and 2 batts. I am not sure on if i should get 2 sundown 3000 watts or one rockford 4000 due to money issues. Also can i run either one of these setups with just a 200 amp alt because thats all they make for the acura integra? thanks
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
if money is an issue then going with the RF is the better choice. also...the sundown 3000D's recommend a 200 amp alt for one of those amps. you might be able to get by with one...but have 2 alts would be ideal (if they'd fit in the integra)
yea i can get 2 sundown 3000s for the price of one rockford 4000 so i was leanin on the 3000s at the moment. i figure i might be able to keep voltage in the 13+ range with one 2 powermaster d3000s with only one 200 amp alt. correct me if im wrong on any of this please.
Edited by Krice420
2 sundown saz 3000d
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 818 Guests (See full list)
