Custom Subwoofer Now For Sale..pg 4
Posted Image
Posted Image
Posted Image
Posted Image
As far as the bed liner spray, it works fine, the longer its on there, the more durable it is. I only used it to pretty up the frame and motor
no primer, just dust off, clean up, and spray away
i have seen that motor somewhere before.......
looks good
let me know if you wanta let it go for $150
i have done alot of business with this guy and hope to do more.....:)
Yeah, thats the same motor bro.... Let me think about the $150. the profit was going to more parts- or- Christmas...
Thanks for the props man.... BTW, I still have 2 more subs to mess with beyond this one, I just need some frames, get me frames for the motors, and I will get you anything from a monster 10" to a 18"
I will take this to Melos if you want to show up, and take a look at it
And that wood ring is just the surround clamp for gluing, I have an actual rubber wrap around gasket for this.
Looking dam good man... You should be proud to bump your own....
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
Maybe, but then I'd have to kill you
:diablo:
Well, there are a few companies, alot are over seas, what Iam doing is since I have a few "hook ups" here in the US, they are getting me the parts, and I am assembling them
Trust me, its so much harder to get proper parts than most think- A spider, coil, and cone- If you want things done right, you need to know things like spider compliance, gauge thickness of coil, windings, how long to order the tinned leads on a coil, OD and ID of spiders, cup spider, or flat, or progressive spider, height of the cone from mounting to coil opening, weight.Lots of factors
i will leave that to you then. i was lost reading that.
----reference's----
meade916
nah, no CF caps, I wish. I has Cf cones, like 225 of them, but the surrounds are to narrow for cast frame subs. But Iam ordering new foam tall surrounds for those cones, since the rubber surrounds on them peel right away. Then I will either sell the cones with foam surrounds, or use them to build up subs with if needed.
This inverted alum dome is causing me a head ache, the leads after soldered still stuck up to high, and is just lightly pressing against the dome
Its comming along great tho, looks pretty last thing to do is the terminals, gotta solder some rings on, and screw to the terminals
and bingo
