ok some guy is arguing with me that if you resin and mat the inside of your box that that makes it weaker because air can't get to it or something
Too many screws bro, and i wouldnt fiberglass the inside it actually makes it less strong. If your looking for better airflow jus resin it.
please elaborate on that
Niz is right, A screw should only be used to hold the pieces together till the glue drys. When the actualy glue dries the glue itself is stronger then the wood. The reason fiberglass makes the wood weaker is because the oxygen cant get to the wood. Wood is a majior source of oxygen hint why its from a tree. It needs oxygen to be strong. If you dont believe me make 2 small boxs exactly the same, one with fiberglass and one without see which one breaks worse.
then if you put resin on the inside It would also weaken it but the strength you get from the matting helps alot as it is rigid and doesn't allow the wood to flex and if you allow the air to get to the wood then it will "soak" through the other side and you will loose pressure inside of the box (to a certain extant) and if you resin and mat the inside and resin the out side it would actually be stronger as the air would be trapped inside sort of like a balloon in mdf the spaces between particles is so small that it doesn't really have the same properties as plywood because all it is is saw dust and glue pressed together at high pressure and heat
so who is right?
heres the original thread
http://www.caraudioclassifieds.org/forum/s...post&t=4240
Edited by wenn_du_weinst
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
WOW, thats all I have to say.
Are yall seriously arguing over air seeping through mdf...
yeah sorta I guess basically he says mat and resin makes it weaker and I say it doesn't so unless there is something I don't know about I'm pretty sure I'm right
yall dumb
R.I.P!
(Nov-29-2009)
92 explorer
current build
well guys, it looks like i wasted 2 gallons of resing and 15 yards of matt giving reinforcement to my box then. oops.
seriously though it adds ALOT of strength.
fyi: i did his experiement. i build 2 sealed boxes for a rfhe 10 one with resin and matt and one with out. the one with out resin and matt lasted only from a 16 foot fall. the other one lasted with me throwing it up in the air as high as i could and then falling on concrete.
Edited by reinke
----reference's----
meade916
hes a retard and mdf isnt exacly from a tree its basicly sawdust and resin smashed together
thats what I said but he just keeps saying test it over and over again
and why am I dumb? I was right
  • Who's Online   2 Members, 0 Anonymous, 1075 Guests (See full list)
