ahh yes that is true. so what counts as a clamshell, do the woofers have to be placed in a wedge shape? with some on top and some on bottom?
DCAUDIO
BALLS DEEP
so how does the box in the caddy work exactly isnt there pressure between the woofers? and wouldnt the pressure push into the port? granted it moves to the path of least resistance, or does it simply not work like this?
oh and anyone in the bay area/norcal check this thread out please:
http://www.stevemeadedesigns.com/board/ind...showtopic=35582
its a liil get together in fremont
Edited by mr.p
DCAUDIO
BALLS DEEP
look into chargers build with 6 15s
chargers build log
R.I.P!
(Nov-29-2009)
92 explorer
current build
I always think of clamshells as how my old boss explained how horns and transmission line works.
in his words the best I can remember,
" Imagine creating a tube with your hands in front of your mouth, now make a low frequency sound firing in to the tube, its quite different than just making the same sound with no tube, impressive, but now make the same sound start with your hands formed in to a tube again, but now this time, slowly open your hands until you find the loudest you can get with out changing the sound pressure coming from your mouth, you will notice at about 45- 90 degrees opened up, you will get loudest, most efficiently"- This you may have to experiment with a second person in front of you, so they can confirm, same way my boss did it to me.
This is the same concept bull horns work to talk to audiences, etc etc. Its about sound dispersion- This is not to be confused with horns, or 1/4 waves, its more based on sound coming from one point, and opening out to a larger mouth to direct sound in a proper manner
Thats my take on clamshells vs flat wall vs wall of subs facing another wall of subs
hhahah wow i actually did that^
yea chargers clamshell is sick! i would love to do something like that...maybe after i pay my explorer off, i just realized that a wall or clamshell would be a seriously permanent install :\ the wall idea i had was just a slidein box witha trim panel for the face, it woudl be fairly easily removeable.....ill figure this out :)
DCAUDIO
BALLS DEEP
