for just the inside of the box it shouldnt matter to much if you have extra mekp.
cause you dont have to worry about getting it to hort and warping.
Ya but won't the shit get to hot and want to start to bubble and possibly smoke but not catch on fire?
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
if its 50 outside i say just go for it..
it was raining out the other day and i was fiberglassing 10pm and left the piece out getting wet lol
Tibs 99 F-150 Build 8 twelves
8 - Re SE 12"s
2 - SunDown Audio Saz-3000d's
1 - vx4004 planet audio amp
big 3 1/0 gauge
MECHMAN 250 amp alt
MySpace
mix a test batch, it should be fine
last time I glassed, the first day was 90degrees, the secondd was 60ish and raining, using the same mixture that set in like 15 mins on the 90degree day, took 3 days at 60degrees, until i finally took a heatgun to it for an hour.
mix it a little hot and you should be set, get a heatlamp in there if possible, or atleast a hairdryer
Team DC
I'm headed out now. I'll let you guys know how it turns out. Thanks!
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
the colder it is, usually the longer it takes to dry. i've done it in the 30's before. i bought a work light for like 10 bucks from wal mart. it's held up so far. maybe mix it a lil hotter to dry a lil faster. good luck ;)
Mix the ratio a little hotter, and use a heat gun to help kick in the curing process, but just only let the heat gun let it START the process. After it starts, then let it go with a heat lamp on it on its own.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
  • Who's Online   0 Members, 0 Anonymous, 753 Guests (See full list)
