My New Oscope Edit! Its Here! Pics Inside!
Grats on the scope! makes life a hell of a lot easier :)
-Drew
uhoh_45 said:
Ill let my boy kandiman put the juicy details in here as he is the first to touch it lol
Looks nice, mine is suppose to get here today. giggity
DC.jpgDC POWER
I wish I would have never clicked on this post. Now there is another gadget I have to have and will lose sleep till I get it :(
LOL me too but its becase i'm buying amps.
Ya Roscoe you have mail man.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Roscoeberry, does it measure gayness level too?
Your levels will be too high, should have gotten the more expensive model to read your level. :P:shok:
BANDT!
replied :)
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
I just got the HPS10SE also and don't know how to use it to check for clipping..... any tips?
EDIT: Clip your probe to a + output and the ground clip to the -. Or if you're doing RCAs take the clip off and wedge the tip into the split in your RCA's tip if it has one, otherwise you'll just have to hold it :P
Set the time/div to 10ms then set the volt/div to like 10V if you're doing amplifier outputs or 200mV if you're doing RCAs.
Play a suitable tone on repeat, turn it up until you see the wave become square. You can let it get a litttttle bit square, it's only like 2% THD and you can get a lot more power by just allowing it to square off a tiny bit and you'll almost never notice the difference.
Make sure you do it with your subs/speakers connected otherwise you don't get an accurate idea of what your amps will output when loaded :)
10.x volts fo' life!
