So if i bought a d1 sub i could strap it a 1 ohm each amp or would that be .5 ohm each amp? i am just considering options as i wait.
Roseville, CA
you can run each amp per coil and get 1ohm per amp, or series the woofer for 2ohms and do 2ohms strapped and each amp will see 1ohm
-Drew
uhoh_45 said:
To answer your question you would need 2 d1 subs to run at 1 ohm and then yes each of the amps would see .5 ohms when strapped. Whenever strapping a pair of amps each amp see's half of the nominal impedence.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
I believe you sir are incorrect. that would be way less than 1 ohm. that would be something like .5 or .25 depending on the sub.
No I am completely correct. You would take the dual 1 ohm coils and wire in parallel achieving .5 ohms per sub. Then wire them in series getting a 1 ohm load. Next you would wire that 1 ohm load to the strapped amps and each amp will see .5 ohms. I don't know where your getting lost here but I am CORRECT.
EDIT:
He was asking if he strapped a pair of amps at 1 ohm would each amp see .5, and the answer is yes whatever the nominal load is each amp see's half of that impedence. I was telling him how he would be able to have each amp see .5 ohms like he asked. Now for a d1 there are a few options. Coils in series at 2 ohms each amp will see 1 ohm, coils in parallel at .5 ohms each amp will see .25 ohms.
Edited by Nightshade
1 XS Power D3100
Audio Control LC6i
Stock Deck
would you not wire it up to 2 ohms and have each amp at 1 ohm?
R.I.P!
(Nov-29-2009)
92 explorer
current build
You need to reread what he said....
If you take one d1 sub and series the coils you get a 2 ohm load. Then strap that and you get 1 ohm per amp.
Edited by banginAltima
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
or just run 1 coil per amp, and set the amps the same
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
This topic is now closed to further replies.
  • Who's Online   0 Members, 0 Anonymous, 1594 Guests (See full list)
