I'm not sure if im using the correct wording by saying "Pole Vent", but what im trying to describe is the bottom of the BTL / BL's dont have a vent on the bottom of the magnet, where as the AudioQue HDC3A's im looking into buying I think DO! Why? What is the difference? Im really looking for my HDC3's to hit really hard, at least as hard as my BL's that I had, and am just doing as much research as I can, without pissing to many people off :) . Is having a pole vent a sign of a driver that can really hit hard, or am I completely wrong? Please, can someone chime in, and describe to me what the differences are? Thank you
I love my staffie :good:
So anti FACEBOOK it isn't even funny
If it does have the vent, it's to help cool the coils.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
To Pole Vent, or not to Pole Vent, that is the question.
In all honesty, it has alot to do on how the drivers cooling system is designed. Just because it doesnt have a pole vent does not mean it is a better, or an inferior driver to another that does or doesnt have that characteristic. most drivers that do not have one, have additional cooling channels machined into the motor structure to actually channel the air around the coil better to force a wind tunnel affect to help cool the coil in a more efficient fashion.
Look up Fi's Bp option that is offered on the SSD and Q series, kind of an example of what is done to help increase the cooling affect...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
i believe a pole vent is the standard for coil cooling on subs
and i think Fi has some new kinda cooling that is better than the standard pole vent but idk
pole vent doesnt mean louder or quieter its a standard
my 3512 has a pole vent and its loud
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
X2...and why would your question piss anyone off??? ***confused***??
Follow my Tweet (Twitter)
not using ones usually creates more pressure around the top plate which gets rid if the air closer to the joint of the former and cone rather than near the bottom of the vc...
the metal used dictates how it dissipates heat too... so for some companies its better to cool thru the pole vent and for others closer to the top plate... most spl subs do not use pole vents
Wut? I'm struggling to think of many that aren't the RE MT or Fi BTL...
DD95/99/Z
Atomic APXX
DC Level 5
T3 TSNS
All got pole vents...
On topic, it's just another way of cooling the coil. Different brands have different theories about whether to use them or not (effect on BL, pressure in the gap, etc etc) but the presence or lack of one doesn't make a sub good or bad.
10.x volts fo' life!
edit* most companies do use pole vents
to the OP... its really hard to tell by magnet weight, bl and pole vents whats going to be best for ur setup.... its moreso the combination of all the specs and the box being built that dictates the outcome
in ur case, just go with the hdc's!!!!
He pretty much hit the nail on the head. It is a combination of the specs of the woofer and the box you put it in that make a woofer perform well/poorly. And like he said, just go with the HDC's Im sure youll be happy. Ive heard several HDC3 setups and cant complain about one of them, well, except the ringing in my ears after i got out of their car, lolz.
In addition to what others have posted, in some subwoofer designs the lack of a pole vent can also increase magnetic strength in the bottom plate by putting more metal around the coil. I believe I read this from some Fi article maybe on ***?
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
  • Who's Online   0 Members, 0 Anonymous, 2907 Guests (See full list)
