The Performer Posted September 13, 2009 Report Posted September 13, 2009 So I was doing a job in a commercial building and I saw a couple of these things lying around on the ground. They are connectors for 2 wire connections used in fluorescent light fixtures between the ballast and the bulbs. The downside is they only handle really low current, 6 amps, but I think they will be perfect for connections for LED's, and between relay control switches where low current is used. Ideal makes them and I believe I'll be able to find them in local electrical supply stores so I'll be picking a pack up for sure. Just thought I'd share, I did some research and Ideal makes a few others like them in even smaller versions and 3 wire versions. I figure there's more of you guys out there that like me can find some uses for things like this that make your installs easier. CERTIFIED BITCHES!!! Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks' Click to see my build! Proud DC owner
Kasey Posted September 13, 2009 Report Posted September 13, 2009 I used to drive electric RC trucks (E-Maxx) Used these grate things called "Dean's ends" there a hi current plug that work grate for quick disconnects for speakers and audioz in general "Audio is not a hobby it's a lifestyle" _____________________________Refs_1_Refs_2_____________________________
Boon Posted September 15, 2009 Report Posted September 15, 2009 Yeah RC quick-connects are good, they'll take a hell of a lot of current usually. You can even get 4-way ones... 10.x volts fo' life!
J00bles Posted September 16, 2009 Report Posted September 16, 2009 i use those same industrial connectors too, after i found some at work. The down side is that they are pretty expensive ($5 for a two pack at homedepot) Cool to hear of another person being cheap! 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
Shyne151 Posted September 19, 2009 Report Posted September 19, 2009 http://www.parts-express.com/pe/showdetl.c...tnumber=095-304 http://www.parts-express.com/pe/showdetl.c...tnumber=095-314 I usually just use those. -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
