Looking good mate, as always
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
This is what happened with the Soundstream amps.
Preamp chips upgraded to give better dynamics and detail. The TL074 parts were a good chip back in the 70's but the new parts now are quieter and better sounding.
New caps to give more stable power supply rails and more stable imaging.
Mica sheets conduct heat better than polyamide sheet so the bias is stable.
Bias sensor moved so bias is stable at all temperatures and loads.
HP / HC Switch removed as it's unreliable. Stereo / mono / mixed switch replaced with a new part as it had been pulled apart and not reassembled tightly - risk of a bad connection.
  • 3 weeks later...
i’ve managed to cover the doorpanels, and it worked out fine.
the carbon fiber panel where the speakers will get into, is about 90 procent finished. I need to sand and polish it a bit more for a deeper shine.
a71ec2ec-ddd2-4020-a426-c08e9cb74daa_zps
Bassreflex is also finished. As you can see I sprayed the middle piece in the same color as the moldings in the car. So I have a nice contrast and still, everything blends in nice with each other.
I need to cover the middle piece of the door, and after that, I can start mounting everything.
I've been in a wheelchair for 15 years, but I've been real lazy the last 5.  I know you're just doing your thing man, and you're not trying to inspire anyone, but seeing your work has helped me to realize I have been wasting my potential.  Seriously dude, seeing your work was a huge catalyst to get me back into rehab and I am going to create some cool things again.  I build custom remote controlled cars, well, I did, and I'm going to again.
Thank you for sharing your work and your life.  My jaw hit the floor when I realized you do all the things you do from a wheelchair.  Keep rolling man, take care of those shoulders!
I isolated the doors.
Before I started, I checked again if no water got into the door when it rains. So I went to the car was, and focusses on the doors with the lance.
At home I took the hose and put it onto all rubbers and cracks. In both cases I didn't see a single drop in the doors. Not bad for a bmw of 18years old.
I already noticed before there was only 1 little sloth (2cm) in the door where there could be a waterfailure.
I chose Focal Bam XXXL   https://www.focal.com/en/car-audio/car-audio-kits-solutions/accessories-and-cables/acoustic-insulation/bam-xxxl
This box contains 3 square meters of damping material. Normally you can do a whole car with this, but when I was finished on the doors, I used almost everything.
  • 3 weeks later...
Doorpanels are about 90% finished now. Here and there I’m planning of doing a small detail which will be original and cool.
Later more about that…
Here an original doorpanel like they come from the factory.
These were the doorpanels I modified once. The bottom part was fully adjusted to make way for the 16cm Focal speakers.
EVO1.
Here some pictures about how they will look now.
Evo 2 (there will not come an Evo 3)
These are some pictures when the white lighting is on, when the door is opened.
On pictures it looks like it’s blue, but in real life, it’s white…
There’s a LED strip underneath the door, in the storage compartment and behind the door handle.
The one behind the door handle needs some more modification, I don’t like it that way
You can also see the white lighting coming out of the bass reflex.
The orange inner lighting was also finished, but it wasn’t like I wanted it to be. The orange strip I’ve used was TOO orange comparing with the orange interior lighting (original BMW)
This one is a bit more red. So some work is planned to get those strips out, and make them more red with a marker.
This will take a couple of hours, but when it’s all done and merges into the rest of the lighting, I’ll be very pleased.
  • Who's Online   0 Members, 0 Anonymous, 825 Guests (See full list)
