I been thinkin about building a wall for some time now but im worried about the weight of it. I have a 92 Mustang and its pretty low now, how much would a wall weigh together and how much lower do you think the rear end will be? I know alot of you guys have a wall in your car/truck did you leave the suspension stock or redo it?
Edited by Street
My Babies
97 2.5 Avenger, 92 5.0 Fox, 97 2.0 Turbo GST Eclipse, 00 2.0 Jetta, 06 GSXR 600, 98 CBR 600, 01 GSXF 600, 93 CBR 900RR
Wilwoods dont slow your car down, they slow the earth down under your car...remember that next time you slam your brakes, you may spill my drink.
it would probably weight about 200-300 with all the subs in and the wood or mdf
Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34
Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
200-300 is very much on the light side, you build walls to go big, multiple subs add up, wood adds up, resin, bracing etc...id say using birch if your worried about weight...my box i have now (which is virtually a wall) weights close to 500 lbs with the subs in
My F-150 Build
GET ON THE BANDWAGON
what if they tried messing with the amps when the subs werent louder :ehh: hahah jk :pardon:
Use Birch or Oak Ply to cut the weight down a ton :)
my car sagged like a motherfucker and it was all birch :( If your that concerned just grab stiffer springs
-Drew
uhoh_45 said:
YOu don't have to use MDF wood because those are very heavy. The biigger the MDF the heavy it's. You can use lighter wood like BIrch. I think those are light but expensive depending on the sheet sizes..
I used MDF ultralight in my crx. My wall turned out weighing 200pounds. That's after a gallon of resin and well over 300 1 1/4" screws. The one sheet of MDFUL weighed in at 60pounds and a sheet of home depot MDF weighed in at 90pounds.
Edit: And to answer your question about you back suspension, I kept mine stock. It dropped the car 3" after I loaded in the wall, subs, and the 110pound nsb125.
Edited by Cuseikan
my non walled HHR has 1500lbs of stereo in it.
The box itself is 250 lbs.
I lowered the front 2" to match the dip in the back.
Most walls I build are pretty beefy and the enclosures themselves would weigh over 1000 lbs.
But thats because I go 4+ layers of 3/4" and use resin/concrete/sand.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
i bought 6 sheets of mdf for my car, i'd guess 4.5 to 5 made it in...at 90lbs apiece thats already over 400
gallon of resin, few yards of glass, gallon of glue, some 2x4's, ...i guess call it 50lbs
3 18's...theyre what 70lbs apiece? call it 200....thats 650
but, 3 huge batts at 80+ apiece-250
4 big amps at 10lbs apice-40
so thats 940, not counting sprayfoam, wires (considerable, prob nearing 100 lbs, 100+ft of 0, dozen fuses and blocks, 60ft of 8g, 100ft of 12g, 3 sets of 20ft rca's, 3ft worth of busbars with 2 dozen 3/8in bolts)...and then theres all that dumb stuff like dynamat, pretty panels, batt/amp racks
honestly its probably over half a ton I added to my car....and its not even a full wall
the box and subs, 500-600+ is right, but keep in mind all that other shit you put in there
Team DC
  • Who's Online   0 Members, 0 Anonymous, 1010 Guests (See full list)
