I will be fiberglass resining and bondo my box a lil more today and its freezin outside wit no sun so ill be doin it inside were its also gonna be kinda cold any tips for it to set up faster? im in no rush im just worried it wont dry period without sun or heat.
6 Sundown X 15s
2 Sundown NS1 V2s
C Pillar 4th order
Bagged Suburban on 24s
http://youtube.com/tlee333
how cold we talking ?
and use a heater or a lamp if you can to help speed up the cure time
if you dont have any of that try bringing it inside to try in a vented area
R.I.P!
(Nov-29-2009)
92 explorer
current build
I use dual 500 watt halogen work lamps. works like a charm. you can make a cook box as well.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Last winter when I was fiberglassing a small sub box it was 15 degree inside with no sunlight...I didn't have a heat or lamps....so I just mixed the resin a little hotter than normal...
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
yeah im gonna have to make a rigged up "box" to cure my stuff in this winter. or use an ice fishing shanty.
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
when i do it in the cold i use $10 halogen lamps i got from wal mart and stick em on there. and mix it a little hotter
X2. thats what I did it worked out fine still took almost 2 days to completly dry
  • Who's Online   0 Members, 0 Anonymous, 2178 Guests (See full list)
