How to control 2 amps with 1 bassknob without strapping?
berniebp87
Got 2 dynaBel BF8501 amps (very similar to atomic 5000 I think) and I`ve tried strapping them, but they shut off when I turned the volume up. This never happened when they were "unstrapped". I want to use just 1 bassknob instead of 2 wich I`m doing now, I`ve been looking at the RF PEQX3, but don`t think that will work with my amps.
Anyone know of a similar product that can gather the remote control wires into 1 bassknob?
Edited by berniebp87
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
154.5@38hz with 2 DD Z9518`s
145.5@40hz with 2 DD 1508`s
My youtube vids
by a rockford amp, control 100 with one bassknob :)
Follow my Tweet (Twitter)
maxx-link
do you have a link to the product? Sorry for the noob Q ;)
If I win the lotto I will :) Way to expencive over here :sorry:
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
My youtube vids
Go to radioshack and buy a Y splitter, is it rj45 or rj11?
Maybe see if there is a master/slave feature on the amps
There is a master\slave feature, but as I said earlier if I do that, the amps shut off (don`t have a voltage issue though) Need something like the PEQX3 :)
Proud member of SMD
My build log
2 DDZ9518
2 DynaBel BF 8501
2 GZ Neo 8"s
My youtube vids
most telephone Y splitters work
R.I.P!
(Nov-29-2009)
92 explorer
current build
that was my thoughts on it...just make sure you get the ones with the same amount of pins for the splitter, and new wire
Edited by z71kris
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
you get what you pay for :) good luck!
