wow man i had no clue u did that many builds in there. This one looks great so far! Keep it UP! :drinks:
Eclipse cd7000
Looking good man.. Wall is rock solid from the looks of the quad baffle + tons of bracing, definitely a proper starting point for 2 18s + 8kw. Can't wait to see the results once everything is all dialed in.
Pioneer AVIC-N2
Talk about a learning experience man
atta boy
R.I.P!
(Nov-29-2009)
92 explorer
current build
A quick update. I'm not going to be adding more inside the car until my bags come in for the rear. I just had the whole front suspension system replaced and now I've ordered parts for the rear. I think some of the next steps are going to be changed in order to minimize the weight. More glass and eucaboard, less MDF. :sorry:
Subs came in though! I can post some pics of those later tonight. They are bigger than I expected.. :yahoo:
Need an install? Hit me up.
[email protected]
i can't wait to see the subs in :)
