That looks awesome. Gotta love Wild Turkey and giant amps!
What are those amps?
Epsilon EA5000D's, an aussie shop started their own brand, used amps almost idental to the Fusion FC4000D's. 4kw at 12v, 5kw 14.4, 6kw at 16v+ i think.
Build is lookin good! I see you had the mach 5 IXLs aswell. I tried numerous tiems to get output abouve prolly 35hz aswell. Never did but KILLED the lows! Get back to work you Aussie! :)
Thats almost the only reason why i'm not using 12 more IXL's, can't have every song chopped and screwed to play 30hz
Sick looking build :) I love the lows....I'm actually redoing my sub box soon for some devastating lows.
Those subs in the corners are sure gonna be fun to load lol...
Tell me about it, gonna have to make a custom tool with a ratchet and philips head screw tip to get it in
are you loading up the back wall with more 2x4s or leaving it as is
As is, to me bracing > layers.
Thanks for the comments so far guys :)
'91 Trooper - 12 x 15's
is there not a gap between the 2x4s and the baffles?
R.I.P!
(Nov-29-2009)
92 explorer
current build
At the back, i'll fill that in with 2x4 and MDF to seal it.
At the sides, 45 degree pine strips + caulk, eventually glassed over.
yeah that what i was trying to get at in first post. btw how much were those amps if you dont mind me askin
R.I.P!
(Nov-29-2009)
92 explorer
current build
looks good, so far you Ausies seem to love doing it big out there
