Road Side Air Line Repair Howto
Heres a short how to on what you can do to repair a popped air line on the side of the road.
your going to need
knife
air line
jack if need be
2 1/2 inch ptc unions im using 1/2 because thats the size air line I have you'll need what ever size union that matches your air line.
you should have this stashed away in you vehicle even if you don't need it you might be able to help a down brother some day.
Posted Image
Posted Image
If its a pin hole leak you can simply cut the air line out so theres a small gap make sure the your cuts are as strait as possible and free of burs
Posted Image
now simply push to connect
Posted Image
Posted Image
if the air line is split or has a large hole cut the air line so the hole is removed then cut your self a fresh chunk out of your spair air line. then use the 2 ptc unions to connect your air line
Posted Image
Posted Image
not shown is a piece of heater hose i carry to. If the air line popped due to it rubbing on some thing you can put the heater hose over the air line. This is only a temporary fix designed to get you home. Once your home remove the patched air line and heater hose and fix it correctly ;)
  • 5 months later...
Great tutorial. With more and more people bagging their vehicles..this will probably be needed here pretty shortly.
not to mention... it will help with overload air bags, and ARB air locking differentials also FTW!!!
Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW=
its a great post P.....something you learn very fast to keep on hand especially if your install is new and the bugs arent worked out yet. Stuff you dindt think would rub a hole in the line WILL.....ive been almost stranded twice and having this in the glove box saved my AZZZZ. (mine were compression not push on but both equally good IMO, Push on being much faster)
This post gets a sticky fo-show...
Follow my Tweet (Twitter)
its also a good idea to carry some extra airline, a flashlight and a few schrader valves in case you bust a valve, you will still be able to get around until you can fix the problem. helped me out on a 400 mile trip once, valve decided to take a "dump" on me in the middle of nowhere at 230 in the morning! it was a great spark show but scared the crap outta me!
2003 Chevy Avalanche Z66
Headunit: Pioneer AVIC-F700BT
Amps: US Amps XT4000D, US Amps XT 1600.4
Front Stage: CDT Audio EF-61FG 6 1/2" components
Rear: Pioneer coax's
Sub Stage: RE SE15D4's
  • 4 weeks later...
  • Who's Online   1 Member, 0 Anonymous, 415 Guests (See full list)
