The Fusion amps aren't bad at all.
Try running some digital silence and see if the subs move slowly. If they do, then it could be a gain issue. If it happens, try turning it down before playing anything again. Then check the voltage on your remote wire against the amp ground with it on. I've seen it do some funky shit when it shorts or has low voltage.
Need an install? Hit me up.
[email protected]
the dual plexi glass box,with neon lights?
Edited by Mellow18
2001 Black Monte Carlo SS chrome 20''
(1) Alpine i-9881 deck-ipod-
(2) DC lvl 4XL 18''s-Walled-
(1) DAT Hellfire - 2500.1-fused-
(1) D3400 XS Power battery-fused-
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
(1) DC POWER ALT INSTALLED BY ROB FTW,Big3
(1) Viper 5901 Alarm + killer yorkies and chihuahas
[EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has
bass in this city, i look out the window and its my mom bumping Gorilla Zoe
I'll try to get box dimensions today.
I had a thought that bad RCA's might have been my problem, so I bought some Scoscheeeeee's yesterday at WalMart just to see if they did the trick. Haven't tried those yet.
Eric - As for the shitty ground, I cleaned up the area of the seat bolt which is where I've used my grounds several times in the past. It's bare metal and looks shiny. And I would have "taken the fucking time" to get a ring terminal but since yesterday was Sunday, no shops besides WalMart were open. And Walmart just had ring terminals for some 10awg wiring.
bealstar - no, what I meant was: The guy who was running the Type R's off of this Fusion amp had his Type R's at 1 ohm. My CVX's are wired at 2ohms. This amp on those Type R's beat the shit out of his car, which is why I bought the amp because I've seen what it can do.
Edited by abaddon
2003 Ford Crown Victoria P71
2 12" Kicker CVX's
Audiopipe AP15001d
Stinger SR80 Isolator with DieHard 1200CCA battery
Streetwires 0awg
Secondary - 1998 Ford Expedition XLT
I see two reasons why this doesn't work"
1st) Switch + and - at one woofer, so the subs play in phase.
2nd) Dump the Fusion amp because that's the biggest crap on earth.
______Some people and performances are beyond words______
Chairman of the foundation "Propper-Droppers Holland" 2012
Founder of the European delegation of `Propper-Droppers' 2011
Dutch Champion EMMA SQ MultiMedia advanced 2010
European Champion EMMA SQ experienced 5 channel 2007
Dutch Champion EMMA SQ experienced 5 channel 2007
BeNeLux vice Champion dB-drag street-A 2007
Dutch vice Champion dB-drag ministreet-sedan 2004
_________________________________________
Propper Droppers is about deep, ground wobbling, elephant-and-whale stimulating Street Bass.
The deep stuff. We test at different frequencies from deep, to low to snake’s belly. (Like 20Hz anyone?)
I know it's a piece of crap, but I bought it cheap enough and knew it would probably pound these woofers.
2 12" Kicker CVX's
Audiopipe AP15001d
Streetwires 0awg
Underpower means clipping and that causes the death of your subs.
So, please think about this when you use the word 'cheap' because it isn't ;)
Edited by General
One thing is you are putting about half power to the subs, in a most likely smaller than spec box, so they are not gonna perform very well. The Fusion Amp is rated at 750rms at 2ohms, that is the RMS for one sub. Combine that with a smaller than spec box and you tend to not get the performance out of the subs. For example my box for my CVX's is a bit on the small side at 1.8 cubes per woofer, but I am also putting about 200rms over the rating to each sub, so it evens out.
It worked on your friends type R's since he had them wired at 1 ohm which at that load the fusion amp put out 1000rms, which was perfect for his Type R's given they are 500rms a piece. I would try what others suggested as well as making/getting a new box, that gives the woofers about 2.5 cubes a piece, if you plan on using that amp for a while.
¿ǝɯɐƃ ǝɥʇ
Your h/u might be taking a crap, try something with rca outputs that you can hookup and try to see if it is in fact the h/u doing. Also make sure the subwoofer output is turned up all the way.
Edited by Skullz
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
My system is now fully-operational and pounding hard. Bad RCA's were the culprit. Just like I had imagined all along. I wanted to thank everyone for their replies and advice, I actually learned a lot by reading the replies in this topic and didn't think I would have as many people trying to help as I did. So for that I thank you all.
2 12" Kicker CVX's
Audiopipe AP15001d
Streetwires 0awg
  • Who's Online   1 Member, 0 Anonymous, 1419 Guests (See full list)
